Intercooler surface temperature?
Has anyone measured the interecooler surface temperature on a hi-po 930? I plan to powder coat the end tank and sides of the core but want to make sure that it won't get hot enough to melt/burn off. Ceramic coating isn't available in the color I want to use.
Old 01-19-2009, 05:11 PM
rsrfan's Avatar
No temperature data, but I believe that powdercoating will be fine. The stock intercoolers are painted for what it is worth. (I am running a C2 intercooler) There is some debate regarding paint inhibiting heat transfer. However, I have been told that if the core is properly sized this is a non issue.
JP
JP
86 930/4 tribute beasty
81 sc beach beater
‘55 Belair
‘40 Ford pickup
Old 01-19-2009, 05:46 PM
Me like track days
Craig 930 RS's Avatar
Won't matter.
RUF ICs come painted FWTW...
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 01-19-2009, 07:43 PM
E-85 sippin drunk
turbobrat930's Avatar
good to go... powdercoat away... just stay away from the fins!!
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk
Old 01-19-2009, 09:44 PM
Smart quod bastardus
fredmeister's Avatar
Inlet temps from the turbo under load are on the order of 350 degrees F which should be max surface temps you will see on the inlet tank. Unless it gets slightly higher from heat soaking after shutdown....but doubt it.
Low emmisity paint might help with heat transfer on the end tanks....read "black paint" but probably anything less than bare aluminum on the cores should be avoided.
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 01-20-2009, 01:18 PM
David's Avatar
I'd be worried about the paint holding in heat. Has anyone looked into black anodizing?
Old 01-21-2009, 05:25 AM
Forced Induction Junkie
WERK I's Avatar
Powder coating will handle the temps but it will affect the thermo-conductivity of the IC. You're sacrificing IC efficiency to look pretty.
My $0.02......Best to leave it as is, have it polished or have it painted with the same type of paint they use for air conditioning condensers, automotive radiators and oil coolers.
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 01-21-2009, 07:18 AM
Basically what I said about low thermal emissive paint. The color black has the lowest heat emissive constant....that is why Porsche painted everything black, white or polished surfaces like chrome are the worst.
Old 01-21-2009, 10:28 AM
What Fred said. I'm told that rough cast surfaces have more surface area than smooth polished ones... Whether you can actually measure a difference in heat transfer rate is another question...
'77 S with '78 930 power and a few other things.
Old 01-21-2009, 08:36 PM
I have the equipment to do this measurement across the intercooler and can definitely record some numbers and post it. I do have a non-stock IC that is polished and it is a huge upgrade over the flimsy poor excuse of an IC that our cars come with.
Yasin
Old 01-22-2009, 07:15 AM
Thanks for the replies. Off to the painter I go.
Old 01-25-2009, 03:10 PM
BoxxerSix's Avatar
Or better yet, send the IC to Swain Tech and have it coated in heat emitting coating.....called BBE. Satin black in color too....
I've just started using this on some Subarus here who retain the top mount intercoolers and it seems to work well. I have yet to try it out on heads and cases on an aircooled engine as Swain says you can apply as such, but I think on my next customer build I may opt a deal with that customer to have it done(I pay for it) so that I can do some testing on the dyno with the coating and see what it does in that sort of application.
Adam Hennessy
Old 01-25-2009, 05:55 PM
Me like track days
As long as the paint isn't thick, I'm bettin' the actual, real, practical difference between paints etc. is almost zilch.
From what I've measured, I'd put efforts into shrouding and airflow through the intercooler -
Old 01-25-2009, 06:46 PM
