930s rule the wasteland
h20cooled7's Avatar
Send a message via AIM to h20cooled7
System pressure?
65 psi to low for system pressure if so which pump should I start with front or rear?
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 01-22-2009, 08:38 AM
Infidel
JBL930's Avatar
Where are you checking it? You can raise/lower the system pressure by adding/removing shims in the fuel head
Jonathan.
87 930, 993 turbo engine, RS Tuning 520PS/515lbf-ft, Arrow Rods, ARP hardware, Solid lifters, G50-50, RS Flywheel, 890nm Sachs clutch, RSR coil overs all round, 993 C4 calipers front, 930 fronts on the rear, Ruf Speedlines.....
Old 540 BMW, XB12S Modified, for being a total hooligan
Old 01-22-2009, 10:50 AM
h20cooled7's Avatar
Between the fuel head and the warm up regulator the manual says 6 bar to 6.7 for system pressure. Im going by the factory manual, and just had fuel head remaned to stock specs.
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 01-22-2009, 04:10 PM
Crotchety Old Bastard
RarlyL8's Avatar
System pressure needs to be ~85psi or so. Start with the fuel filter.
Old 01-22-2009, 04:22 PM
h20cooled7's Avatar
I replaced the fuel filter, I added shims and the pressure still will not go up! i took the relay out of pump 2 and the 1st pump sounds good. I put back relay 2 and removed relay 1 and the 2nd pump sounds like crap!
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 01-23-2009, 03:58 PM
