Billit injector blocks
Putting out a feeler to find some billet injector blocks for the "Old Sled".
I need standard 930 32mm. Thought some the EFI guys might be of some help. THANKS !!!!! Cole
Cole - 80 930 "The Old Sled" Mods: TurboKraft Custom IC, 934 Headers, GSX 61, Zork, Port Work, SC Cams, Air Mod Fuel Dist Relocated, Water Meth Injection, BL WUR, MSD 6530, Greddy EBC, Synapse Bov, Short 2nd & 3rd with 8:37 R&P, Wevo Shifter, Coupling, and Mounts, MTX-L SSI-4, Big Brakes, Rebel Coilovers, Bilstein Sports. |
Metal Guru
Paul B. '91 964 3.3 Turbo Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb |
Try Chris Carroll at TurboKraft in Arizona.
JP 86 930/4 tribute beasty 81 sc beach beater ‘55 Belair ‘40 Ford pickup |
2nd on TurboKraft
88' 930 03 Tacoma, 04 Duramax, 06 R350 Benz If you are traveling at the speed of light & turn on your headlights, does anything happen? |
Me like track days
Great idea - with the insulators (a must) you have one hell of a setup.
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno |
Thanks for the suggestions. I have heard a lot about Turbocraft but have never
bought from them. Would anyone happen to have a set of billet blocks they have replaced when converting to EFI before I go buy new? Those Turbocraft blocks are pure art. THANKS AGAIN !!!!!! Cole
Cole - 80 930 "The Old Sled" Mods: TurboKraft Custom IC, 934 Headers, GSX 61, Zork, Port Work, SC Cams, Air Mod Fuel Dist Relocated, Water Meth Injection, BL WUR, MSD 6530, Greddy EBC, Synapse Bov, Short 2nd & 3rd with 8:37 R&P, Wevo Shifter, Coupling, and Mounts, MTX-L SSI-4, Big Brakes, Rebel Coilovers, Bilstein Sports. Last edited by cole930; 02-01-2009 at 10:26 AM.. |
The problem with used injector blocks is they are plastic, phenolic, & may end up cracking on you. Correct me if I am wrong, but the heat from our motors can cause the phenolic blocks to become ridgid, which can crack, hence leaks may occur. Something to think of when going used.
How much does a set of billet injector blocks costs for grins?
more than i would pay...
CIS Injector Blocks
$495.00 |
2275T MS EFI '65 VW Panelvan http://www.vvwc.ca/minstone/ |
Daily Driven 88,
I am not cheaping out here. My original phenolic blocks are presently crack free. I was not looking for used phenolic blocks, I was looking for used billet blocks. When most users convert to EFI they change intakes and use fuel rails. I simply thought, by chance, one of those users might have had billet blocks with his original set up that they would be willing to sell. I am not cheap. I simply have a limited amount I can spend. In the past 3 years I've had a Heart Bypass and then got Cancer that required 7 additional operations. I just finished Chemo that consisted of three treatments a month for 6 months at $14,000.00 a treatment. It presently isn't prudent to take money from the household to buy parts for "The Old Sled". Consequently I sell the parts I'm replacing to fund the new ones and that requires me to shop before I buy. Cole
Cole - 80 930 "The Old Sled" Mods: TurboKraft Custom IC, 934 Headers, GSX 61, Zork, Port Work, SC Cams, Air Mod Fuel Dist Relocated, Water Meth Injection, BL WUR, MSD 6530, Greddy EBC, Synapse Bov, Short 2nd & 3rd with 8:37 R&P, Wevo Shifter, Coupling, and Mounts, MTX-L SSI-4, Big Brakes, Rebel Coilovers, Bilstein Sports. Last edited by cole930; 02-02-2009 at 08:25 AM.. |
I would rather be driving
Those injector holders are the $hit!!! I can see so many new applications for such a product.
Thanks for the link. I will be waiting...
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
After the next project
Turbokraft
I also have Chris's blocks from Turbokraft. They worked great and I am very happy.
Thanks, Bryan |
Do you ever get any hot start roughness/sputtering caused by heat transfer from the heads into the metal injector blocks causing fuel vaporization in the injectors and lines shortly after a hot shutdown?
Seems that would or could be the only summertime drivability problem with metal injector blocks, and thats why the factory used phenolic resin or bakelite for them... to insulate the injectors from cylinder head heat. I just wish they made them with thicker walls so they can be hogged out to 38mm without making the walls so thin they crack and crumble when tightening down the intake manifold nuts |
Thoughts
JFairman,
I think the fact that the billet blocks come with the phenolic spacers answers your question of heat transfer and why they were designed that way. The benefit is what you mentioned regarding "going bigger" and Chris at Turbokraft told me they have never had any issues with heat. I was curious about the same thing when I was looking for a solution to my stock spacers. Bryan |
cool, thanks for the info.
The old BMW 2000CS, 2002ti, and Mercedes 190SL came with Solex 40PHH dual sidedraft carbs and similar phenolic spacers between the carbs and short manifolds for the same reason... to try and stop heat transfer fuel vaporization. They would still vaporize and boil gas over from the float bowls into the primary venturis after a hot shut down though. Weber DCOE carbs aren't quite as bad about doing that. |
I was worried about the heat transfer as well. I wasn't sure if the injector itself not being isolated and directly attached to such a big piece of aluminum heat sink would have caused problems.
I ended up boring mine out to 31.5 mm (if I remember correctly) I think after all the good reviews and not seeing any evidence of the heat soak problem I may have to buy a set when the time comes around.
The Blocks that are pictured are 38mm. I bought them for use with SC heads.
