beancounter
jwasbury's Avatar
New exhaust system install - "I'm going in!"
SSI system by RarlyL8 was delivered this week. Phase I is completed. I got the old exchanger nuts off without much difficulty; no broken studs. I've been soaking them with Kroil once per week for the last 3 weeks. Used MAPP torch to heat them cherry red and most of them came right off. About half of them came out with the stud. I am prepared with new studs.
Question: should I use anything on the new stud threads? Anti-Seize? Loctite?
I hope to get the entire job done along with K27 install over the long weekend. Please send me positive 930 vibes
I'll post some pics once things get interesting.
Jacob
Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690
Past: 2009 997 Turbo Cab / 1979 930
Old 02-14-2009, 12:14 PM
torresmd's Avatar
Sounds like a perfect weekend to me. Post some pics and sound clips!
1998 993 C2S Guards Red/Black
1990 964 C2 RWB project car
2016 GT3RS White Daily driver
2018 Lamborghini Performante Gegio Telesto
Old 02-14-2009, 12:23 PM
930gt-40r's Avatar
Most definately use anti-sieze on the studs/nuts- and both sides of the studs. This way instead of snapping, the stud will just back out next time you take it apart.
Now for re-installing the headers, try to get a torque wrenc on them- I know it sounds like over kill, but it makes a world of diffrence, and get ready to re-torque them after a few heat cycles.
You got the hard part done, now you get to relax and just put her back together and enjoy Brian's exhaust.
Kris @ Tech9
86' 930/GT-40R Sold
94' Rustang GT daily (long gone)
2008 C6/Z51 Corvette
Old 02-14-2009, 02:41 PM
A930Rocket's Avatar
I used anti-seize but at the temps they see, I'm not sure it does any good. I know it didn't help on my turbo...
What nuts are you using? I used the copper iamb nuts with new ARP(?) studs in hopes if keeping them tight.
Old 02-14-2009, 02:55 PM
beancounter
jwasbury's Avatar
I'm using OEM bits. Will check tightness after a few heat cycles.
Jacob
Old 02-14-2009, 03:34 PM
Wo ist die Rennstrecke?
DonE's Avatar
Use copper-based anti-seize. It seems to work better than the standard stuff on the exhaust studs.
Old 02-14-2009, 05:14 PM
TroyN's Avatar
Congrats, and good luck on the rest!
'01 996, w/ LN IMS!
Past: '96 993, '98 986, '82 911, '99 986, '87 930, '86 951, '85 911 GTS3 race car
Old 02-15-2009, 08:46 AM
beancounter
jwasbury's Avatar
Part II
Yesterday I just got the exchanger nuts off. Today I pulled the bumper, muffler, then dropped the entire system as a unit. Looks empty underneath now:
Inspected the exhaust ports and everything looks pretty uniform (whitish color) between the cylinders, and no serious ugliness that I can see. I did notice a little area of wetness on the #6 valve which I am curious about...wasn't really ugly though...
Here's the latest addition to my boneyard:
And speaking of ugliness, this is not pretty, but I knew about it when I bought the car. Its been getting worse though:
Now this I was not aware of...new perhaps, but very ugly:
Next up, remove turbo. Then I get to bolt it all back together with the new stuff.
I want to chase out the threads before I install the new exhaust studs. Anyone know what size tap I will need?
Jacob
Old 02-15-2009, 10:24 AM
Certified User
billjam's Avatar
M8 x 1.25 (8mm diameter x 1.25 mm pitch)
Bill
1988 Carrera - 3.6 engine with ITBs, COPs, MS3X
2024 Macan S
Day job ... www.jesfab.com.au
Memories: '68 912, '72 911T, '80 911SC, '84 911, '85 930, '86 930, '87 911, '21 Macan S
Old 02-15-2009, 07:56 PM
That is the correct size tap for cleanin out threads however you would be best not using a brand new tap in my opinion and use a older worn tap or even grind a couple slots/grooves up the length of a new bolt and screw in, half turning it back every full turn or so to clean out crap inside the thread.(old trick used to do in my toolmaking days after heat treating steel) Using new tap it is very easy to also cut into thread in soft material of the cylinder heads and oversize making the stud not so tight in thread.
SP Autobahn www.spautobahn.co.uk
Porsche inspector for Peter Morgan UK
http://www.porscheinspections.com/
"92" 964 turbo,Modified and recently rebuilt using all ARP hardware..
Purpose built fuel controller set up to acheive perfect fuel curve on CIS inj.
Old 02-16-2009, 05:42 AM
torresmd's Avatar
Looking good. I wonder what the weight difference is going to be between the the old and new?
Old 02-16-2009, 07:47 AM
beancounter
jwasbury's Avatar
Progress report
Not done yet...but moving along
Got to here Monday night:
Yesterday continued work on turbo bracketry modification to accomodate K27 turbo upgrade
Aside from the holes/slotting to allow for the larger turbo my bracket needed some material removed for clearance (area indicated)
Getting close now
Jacob
Old 02-18-2009, 08:51 PM
torresmd's Avatar
Looking great. Cannot wait to hear of your impressions when finally done. Can you also post a video clip if not too much to ask.
Old 02-18-2009, 09:06 PM
Awesome work! some fiddling with the bracket is normal but it is surely better than leaving it off completely. Is that a 7200?
Old 02-19-2009, 12:32 AM
Banned
Jacob-
Good show Watson - truly fantabulous. And I am insanely jealous.
Can't wait to hear the results (literally) - you must be *jazzed*. Good fer you!
Old 02-19-2009, 05:55 AM
Banned
ps. you bastid - I'm finding mesself gazing transfixed at your ^pic^ now. Something about the blue / silver justposition and the 'lines' of the turbo / can / piping. Just awesome. It's like you near firckin HEAR IT just sitting there.
Given the opp (someday), that's likely the route I'd go too - real decent setup. Kudos.
Old 02-19-2009, 06:00 AM
Porsche-Poor
bcoats's Avatar
*****in dude, nice work, the 930 gods have been with you!
1979 911 RS clone hotrod
1983 930 turbo-sold, will be missed
1992 964 C2 Coupe-regrettably sold
1980 911 SC Weissach-regrettably sold
1975 911S-sold but not forgotten
Old 02-19-2009, 10:09 AM
beancounter
jwasbury's Avatar
I appreciate the words of encouragement gents...
I promise to give a full report of my impressions when its finished, and hope to do a video/audio clip as well.
The new turbo is a 7200, a K27"S" to be precise.
Jacob
Old 02-19-2009, 12:03 PM
Send a message via AIM to Ag02M5
Color is sweet. Alot like tahoe blue. Rock on.
WTB: 964/965 Turbo stuff...carbon fibre bits, Techart wheel parts, RS/lightweight flywheel, 993 EVO uprights, G50 gears or 6 sp., 964 RSR swaybars, custom droplinks and any other cool stuff, pm me! Also a nice medium build 327 Chevy engine.
Coming SOME DAY...1991 3.3 turbo, Tahoe Blue Metallic with some mods
Old 02-19-2009, 02:47 PM
Great work and great thread!
Those headers look awesome, and I do too love the color, but then I may be a bit biased.
Now to only get mine turbocharged......
Jeremy C.
Why's he calling me meat? I'm the one driving a Porsche. (Bull Durham)
----Nothing is far away in this car!---
-2001 996 Turbo
Old 02-19-2009, 04:26 PM
