ibanezjs
ibanezjs's Avatar
Rear valence for Zork tube?
Hello
Do tou know where I can find a rear valence shorter to use with a Zork tube?
I'm French, so please, use simple English
Old 02-16-2010, 07:28 AM
sudo apt-get purge 930
equality72521's Avatar
Send a PM to Brian (Rarlyl8) http://rarlyl8.com/
--clutch-monkey
Old 02-16-2010, 07:43 AM
ibanezjs
ibanezjs's Avatar
Hi
Thanks, i know his shop, i buy here my zork.
Old 02-16-2010, 08:41 AM
He also sells the rear valence you are asking about.
--clutch-monkey
Old 02-16-2010, 10:56 AM
ibanezjs
ibanezjs's Avatar
Hello my Zork is mounted
Old 02-23-2010, 06:57 AM
Crotchety Old Bastard
RarlyL8's Avatar
Arnaud,
The zork tube is designed to exit under the stock valance so you should not need a new one. Fitment does vary from car to car. Your bumper is off so you can push it up now if more room is needed.
The zork is all business on boost! Love those turbo whistles.
Old 02-23-2010, 07:56 AM
ibanezjs
ibanezjs's Avatar
Ok Brian, i will try certainly tomorow if the weather is better
Old 02-23-2010, 09:06 AM
ibanezjs
ibanezjs's Avatar
Hello
It's finish, but the rear valance don't mount, too long!!
I'm going to wait to see what i'm going to do.
Old 02-24-2010, 06:51 AM
ibanezjs
ibanezjs's Avatar
I think that as my motor mounts are new(8 months), the engine is higher so the rear valance cannot be mount...
Old 02-24-2010, 08:17 AM
RarlyL8's Avatar
Did you remove the zork first, mount the valance and then re-install the zork?
The valance has no room to wiggle into place if the zork is mounted.
The zork was designed to fit close to the stock valance but not touch. I have seen a couple of installs where the zork was 1/2" into the valance due to aftermarket headers and turbos that changed the stock location slightly.
It may be the picture angle but your engine appears farther back than typical. Do you have the stock 4spd in the stock location?
Old 02-24-2010, 09:00 AM
ibanezjs
ibanezjs's Avatar
Yes i have the 4 spd.
I need 1/2" to mount it...
Old 02-24-2010, 09:18 AM
RarlyL8's Avatar
There are a couple of choices.
You can relieve/cut your current valance, you can add the fiberglass valance or you can relieve/dent (smoothly) the zork.
321 is very plyable if not yet heat cycled.
Old 02-24-2010, 09:48 AM
Brian,
Can your Zork be mounted without removing bumper and valance ? Looks tight...
Old 02-24-2010, 11:15 AM
RarlyL8's Avatar
Yes, that is the prefered method. Removing the stock muffler is a different story ...
Old 02-24-2010, 11:30 AM
ibanezjs
ibanezjs's Avatar
Ok i find a used rear valence, so i will cut and paint it.
I will cut the Zork too, because it's too long for me.
Old 02-25-2010, 12:11 PM
ibanezjs
ibanezjs's Avatar
It's better like this!!
Old 02-27-2010, 02:54 PM
ibanezjs
ibanezjs's Avatar
Hello guys
Finally i fopund one rear valence and it looks great for me
After cutting an the paint
On the car
Old 07-14-2014, 07:50 AM
dos531's Avatar
I love it! Looks so clean with the one pipe and euro bumperettes.
'86 930 Guards Red - EFI MS3Pro, 80lb inj, 3.4, GT35R, Tial 46, Bosch 044, B&B Headers, 3.2 carrera manifold, Turbokraft Full bay IC
'12 Gallardo LP-570-4 Performante
Ducati 748R
Old 07-14-2014, 10:09 AM
Kozmo930's Avatar
This Brians new design Zork and waste gate pipe , small eyebrow cut with die grinder to clear is all
Kozmo
Old 07-14-2014, 10:14 AM
Tinkering Pays!!
mooney265's Avatar
I have the same look. One thing I realized is when the engine heats up, the pipe tends to move a bit to the Right [Passenger] Side.
See picture. I had to "elongate" my opening to compensate for this...
LIVN80S - - Red '79 Porsche 930 Steel Slant Nose Conversion [in 1987] w. 46k miles 3.3L; 964 Cams; K27HF @ 1.0 BAR, with Garrettson Intercooler; Rarly Zork; CIS Flowtech Fuel Head & BL-WUR.
Old 07-14-2014, 11:15 AM
