I think that has been done since boost was not cut. I will soon start a thread on my car to help discover what has been done but talking to a few Porsche shops that know the car well said the 28 year owner has built a top motor. After research I do know it does have the 7006 Turbo so far and Twin plugs. If something happend to the engine would it have smoked by now? It has no smoke at all even on cold start nor does it feel like anything is wrong?
1979 Porsche 930 |
1979 Porsche 930 |
everything is fine and you just dodged the bullet! Unfortunately, even small amounts of knock will shatter top compression rings to pieces. Top vent goes to open air (but it should have a banjo fitting and short line to keep out the moisture though) Bottom hose should go to boost line. This is the stock installation. Bottom metal line is going to intercooler and top one is just a short piece of pipe. ![]()
Thank you for your time, Last edited by beepbeep; 03-14-2009 at 11:06 AM.. |
[QUOTE]
Ill have to see about the compression and leakdown at this point it runs and drives like nothing is wrong and I will also look into putting a line on the top of the WG to improve on the current setup. So any pinging would case the compression rings to shatter? So the engine could be tested to be good even with shattered rings? I still need to find the place this hose went in the first place?? The only place on the IC that a hose would fit, it is taken? I was hoping from the pictures someone might comment on this? It can been seen going from the IC to the throttle body. Is this how everyones IC is?
1979 Porsche 930 Last edited by Porschepilot79; 03-14-2009 at 02:54 PM.. |
Do you have a stock intercooler? I want to say there is a fitting there for the line from the side of the WG.
Correct me if I'm wrong, because it's been a long time since mine was stock... |
No its an upgraded IC and the only one fitting is on the IC and I put a picture of it with a hose going to the throttlebody. Is this the way it is supposed to be?
1979 Porsche 930 |
No. What would it be doing? Run your WG line to the intercooler. Make sure it's the pressure line and not the vent on top if the WG. I would say plug the line off the TB but where is your dizzy line run to? It should go to the TB. At least mine is.
What is the dizzy line? I took the intercooler off to take shots of the hose coming off the throttle body and going into the intercooler. So basically its going from one pressuered place to another which makes no scene to me? I thought the WG hose would go on the intercooler always but ??? Here where its connects to the TB ![]() Here is a longer view of the same hose off the TB ![]() Where does this go on your car or all 930s for that matter? Thanks!!
1979 Porsche 930 |
Where does the blue open hose facing up from the left - on that shot - hook up? The orientation, length and location of that hose appears to be the one going to the WG from the IC. I have no clue of the purpose of what is connected to that IC nipple now - going to the TB.
Thanks George
1979 Porsche 930 |
That left open hose from the WG connects to the IC right at the IC nipple FOR SURE. I believe it is even the right lenght to do so.
The other one from the IC to the TB - I don't know what that is. I've never seen that connection before. Sorry |
Ok cool then Ill start with that? I looked on the parts diagram and that it helping and also that sticker under the declid might also help so Ill see what I can find out. Once I get this sorted out I can work on the rest of the tuning that others mentioned here.
1979 Porsche 930 |
Halleluyah! I have finally figured it all out. I spent a lot of time searching here an found out important information on some the vacuum system of the 930.
So that line in front of the TB goes to the thermo time valve which in turns goes to the distributor. I can Plug the TB because my car has a crank fire and has no distributor. Here is a link that has some good info on this system Aux air valve questions Now I need to see how important this Auxiliary air valve is because my intercooler doesn't have the fittings for the hose that come off of it. I guess modified cars disable these systems for performance?????
1979 Porsche 930 |
You're getting there. You can run the line from the TB directly to the Dizzy. While your at, remove all the smog stuff....
![]() [QUOTE=Porschepilot79;4550048] So that line in front of the TB goes to the thermo time valve which in turns goes to the distributor. I can Plug the TB because my car has a crank fire and has no distributor. Here is a link that has some good info on this system [QUOTE] |
[QUOTE=A930Rocket;4550554]You're getting there. You can run the line from the TB directly to the Dizzy. While your at, remove all the smog stuff....
![]() [QUOTE=Porschepilot79;4550048] So that line in front of the TB goes to the thermo time valve which in turns goes to the distributor. I can Plug the TB because my car has a crank fire and has no distributor. Here is a link that has some good info on this system Thanks man im trying! I getting a crash coarse on the 930 engine hehe. So what is this Dizzy???? I don't have a smog pump, if thats what you mean by smog stuff. It also has headers that look like the B&B kind as far as I can tell?? Im going to start a new post about unraveling the mystery parts of my car. It should be exciting! Also, what was the reason that someone block the hose on the Auxiliary air valve?? Should I hook it back into the Airbox? ![]()
1979 Porsche 930 |
My mistake. The dizzy is the distributor. You don't have it so...
Pull the plug, hook it back up and see what happens. It can't hurt it.
They may have done it because the decel valve was bad? Or who knows... |
1979 Porsche 930 |
Kris @ Tech9 86' 930/GT-40R Sold ![]() 94' Rustang GT daily (long gone) 2008 C6/Z51 Corvette |
Would it cause the care to have a hard cold start??? So far thats one problem I will need to solve. Im not sure if the hard start is from the WUR or AAR?? Thanks
1979 Porsche 930 |
Thread Tools | |
Rate This Thread | |
