Porschaholic
What component resets in 7 minutes?
Hey guys your local problem child again...
At least on a quarterly basis I will be driving (mello and typically on the freeway) AND MY CAR JUST SHUTS OFF... for no apparent reason. So here's the drill... I pop the hood and open my fuse box, pull out my two red fuel pump relays... blow on them, rub them on my shirt... re-install them, wait 4 1/2 minutes and the car fires right up and I'm on my way... until next quarter. Best guess wins a prize... thanks boys!
Martin B Orange County, CA. 1986 930 Meteor Grey Yes it's fast... and no you can't drive it! |
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ. |
Porschaholic
you mean this relay?
You mean this $150.00 relay? Yeap, replaced 3 months ago.
Well then it just has to be toast again, for me to win! Since you replaced it earlier, and the problem (I assume) went away - only to resurface again, perhaps that suggests some bad wires in the socket the relay plugs into. You would have get under the socket to check them out.
OK, one more idea....maybe a stretch. How about the ignition shut off time delay relay (the smaller of the two silver "cans" in the rear)? If it malfunctioned, it could shut off your fuel pumps, just as it's supposed to do when you turn off the key (but it keeps the spark going to burn residual fuel for a couple seconds). Oh hell...one more idea and I'll quit. Check the overboost sensor (mounted to the back of the boost recirculation valve assembly with a single wire going to it). That sensor should route the wire to ground under normal conditions, and interrupt the ground when boost is exceeded. A bad ground, sensor, or wire would shut your pumps down. Question: Why are we assuming this is fuel related in the first place? Just because you pull the pump relays and 4 1/2 minutes later she starts? Will she start after awhile even if you DON'T pull the relays? Could be spark related, CDI or MSD.
Porschaholic
Mark: I wasn't suggesting a fuel related problem... more of an electrical problem. When the car shuts down and I pull over I can't just sit there I have to look like I know what i'm doing (even though I don't) it's just part of the routine.
It's suggestions like "boost recirculation valve assembly" I love the most... I'm like duhhh what? I'll check (I mean I'll have the the silver cans thingamajigs checked) so what were the other 47 thoughts you had? kidding... thank you for your prompt reply and humor. :-)
Now THAT I can relate to! As if it isn't embarassing enough to break down, ya gotta look like you know what you're doing. Does she sputter to a stop, or just plain quit like turning off the key? You might be having ignition problems, i.e, the CDI or whatever you're using for an ignition module. I don't know how to test them, since I am no longer stock and run with an MSD6AL. Find someone who can let you borrow their CDI for the next quarter and see if it continues to happen. You need to do some basic troubleshooting next time this happens. Leave the key in the on position, reach your left hand back behind the fuel head near the top and pull the plug from the electrical connection to the switch that is triggered by the fuel head control arm (assuming you're not EFI). Pull that plug, and the pumps will start. If they don't, it's fuel system related. Damn intermittent things drive me crazy...much easier if they just permanently break.
A fellow Pelacanite
I would say CDI.
I posted some bench tests using a meter on this forum. My stock 930 coil has a primary resistance of 0.7 ohms. + to - Quote:
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG. Fitting - New service kit. Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head. 1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods. Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit. http://www.danasoft.com/sig/Iamnotanumber.jpg Last edited by NathanUK; 05-09-2009 at 12:48 AM.. |
