the car has the stock waste gate but has a manual control knob under the dash. this mod was done in 1980 before I owned the car. what is the advantage if any does the after market waste gates offer? ThX GB
The stock WG is good, but if you need to rebuild it, it's cheaper to buy a Tial WG. Different springs are available for the Tial vs the stick unit. Also, I believe parts are cheaper to rebuild the Tial as well.
Turn Knob for loud KABOOOOM. Very expensive.
AMG V8 SL55 Mercedes, 993 C2, 86' Carrera 3.6 hot rod, Purple 1998 993 that didn't make the cut, 3 very old 930s, A/Fuel Dragster CH3NO2 (R.I.P.), Blown Alcohol TAD, AA/AA, 360 Maxim wingless, Cummins Turbo Diesel. Amateur Welder, Painter and sculptor sort of. - |
thanks for the explanation. I used to run a miller wood 7 injector and about 10 yrs ago I switch to the andial enrichment system on a euro full head. while dynoing the car I played with the differnt settings. I saw an improvement when going from settin 2 to setting three while running 17 psi. I didn't get any enprovement going to the 4 setting but I also didn't increase the boost either. What i saw was a 6hp at the rear wheels. I also monitor my IN/Out temp on my Monster Garretson I/C. I ran a little rich at 3500 ( 11.28 ) and from 3000 to 6000rpm I was at 12.0 to 12.10. My only problem was the turbo that I was using ran out of steam at 5200rpm. But not before I recorded 387 hp and 394 tq at the rear wheel. the turbo was a modified 3LDZ. gb
