DSPTurtle's Avatar
Clutch Porn
These are some beautiful pieces. I bought this as a kit to replace the huge pressure plate with one from the early turbo. The CNC ring and throwout bearing extension are works of art. It is a shame that this is going to be hidden away from daylight... once I finally get the darn motor back together
JB - BreitWerks
www.breitwerks.com
321-806-8664
Engine Rebuild & Restorations
Old 07-09-2008, 11:03 AM
resident samsquamch
sand_man's Avatar
What's the story? Is that from Kennedy Engineering?
-jeff
Old 07-09-2008, 11:35 AM
DSPTurtle's Avatar
Is it possible that our host sent me the wrong clutch alignment tool? The tool is too small to truly center the disk??? Or is this just how these tools work? I seem to remember one that I used for my BMW fit perfectly.
Anyway, here is a comparison pic of the pressure plates. Jeez this stuff is cool. I weighed each on a bathroom scale... stock PP = 24 pounds. Early style PP with the adapter ring = 11 pounds. That is a reduction of 13 pounds at the pressure plate!!! Rotational mass here we come. The replacement flywheel matched the old flywheel at exactly 10 pounds. So in total I am going from 34 pounds down to 21 pounds. That is a 38% reduction... I wonder if the thing will even idle
Not ignoring you Sandman... my local guru just told me to shut my eyes, pay the bill and take the parts home and install them for an instant smile. I will find out where they were sourced and post on here. But, the theory behind it is that the disc and flywheel are stock 1985 turbo. The PP is from an early turbo which is much thinner so you need an adapter and a special throwout bearing extension to get all of the measurements squared up.
JB - BreitWerks
www.breitwerks.com
321-806-8664
Old 07-09-2008, 07:41 PM
Wer bremst verliert
JohnJL's Avatar
I received the wrong alignment tool here too. In substitute I've used the handle of a screwdriver that fit snugly. That seemed to work fine 3x.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 07-10-2008, 04:18 AM
DSPTurtle's Avatar
I ended up just wrapping masking tape around the shaft until it fit snug in the clutch disc. Seems to be okay but won't know till I actually insert the mainshaft... three months from now
All torqued up and ready for action...
JB - BreitWerks
www.breitwerks.com
321-806-8664
Old 07-10-2008, 05:53 AM
resident samsquamch
sand_man's Avatar
Giving this a bump.
I'd like to know more about this set-up.
I've got about 15,000 miles on my last clutch job, which consisted of a stock PP, stock T/O bearing, and the early spring centered disc from the 3.0L Turbo. I have recently replaced the clutch cable and ensured that all is adjusted properly. However, the pedal just doesn't have a good feel. And sometimes under spirited acceleration, I can actually feel the clutch pedal snap back into place - towards the rear of the car. I'm thinking that the T/O bearing could be hanging up on it's guide tube in the tranny bell housing. The "Omega" spring under the tranny might also be losing it's tension...and yes, it's installed correctly And the clutch spring on the pedal cluster isn't broken.
When I find some free time, I plan to pull the engine/tranny and have a look. So if need be, I'd like to have clutch replacement parts on hand, in case it's all just worn out and in need of replacement.
Think there are any issues with losing this much rotational weight from the crank? My car is a daily driver...with a fair amount of engine mods...probably pushing about 390HP with the HFS turbo. I thought about going with the KEP pressure plate, but remember hearing of some fitment problems.
-jeff
Old 07-24-2008, 12:53 PM
resident samsquamch
sand_man's Avatar
I did some more digging, and Patrick Motorsports sells these conversion parts. I'm very seriously considering it. That's a shizzle load of weight to lose!
-jeff
Old 07-24-2008, 05:06 PM
Magpie's Avatar
Light clutch in my 79.
If you don't mind loosing a bit of drivability (your going to have to slip the clutch a little). But you are going to really enjoy the faster spool-up. I got rid of air and also replaced the heavy steel pulley w/a half pound Al unit. I lucked out and found an NOS 75-77 930 clutch on Ebay cheap; bought the extension ring and t/o extension from Patrick. The trick to assembly was to use my freezer to shrink the Al parts, which went together very easily that way. You don't even want to be forcing any of those parts together. \The snap ring for the t/o bearing is a pain, but patience wins out.
Old 07-24-2008, 05:22 PM
resident samsquamch
sand_man's Avatar
Looks like Patrick Motorsports also sells a lightweight (13 lbs) KEP pressure plate that requires no conversion parts to fit my car. I might give it a go...
-jeff
Old 07-24-2008, 05:33 PM
DSPTurtle's Avatar
After about 120 miles of driving today I can say that the smaller pressure plate forces you to be much more focused when you are shifting. If you push in the clutch and don't get off the throttle at the right time the motor will definitely spin up between shifts. No big deal, but a little different then the stock setup. Take offs seem the exact same, although the clutch pedal is much easier to manuever. As for performance, it still has a soft bottom but pulls like a biatch on boost. I have not had to slip the clutch or noticed any negative effect on driveability. Seems like a decent upgrade so far
JB - BreitWerks
www.breitwerks.com
321-806-8664
Old 07-26-2008, 09:37 PM
Smart quod bastardus
fredmeister's Avatar
What is the difference in response off idle speed. Particularly if your sitting in the driveway and rev it up does the engine respond much quicker and pick up revs and drop them fast or not so much improvement.
My stock 79 turbo seems to take alot of throttle before it moves the tach, whereas my 79 911SC jumps up and down with the gas peddle.
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 01-08-2009, 05:26 AM
resident samsquamch
sand_man's Avatar
FWIW, I'm running the KEP Stage One on mine, which weighs in at 13 lbs. The idle is fine. The engine definitely revs quicker and hits my limiter (I'm on twin MSD 6AL CDI ignition boxes) with ease. The pedal feel is wonderful! No regrets. I'm also running the K27 HFS turbo, so it already spooled pretty easily.
-jeff
Old 01-08-2009, 05:47 AM
juicersr's Avatar
Jeff, what is the KEP stage one rated for torque/hp. Their website is either a little unclear or i am tired from work. Could you email me about your set-up, cost, etc. I suspect i have some sort of racing style clutch set-up that requires a little finese to get going. Great for highway/track, but gets a little annoying around town.
'79 930/934 replica
80 RSR-look(Now in Sicily)
914/6 2.7 (Projekt 908/3)
1965 Karman Ghia-Class winner 2007 Carrera Panamericana/Ducati 900ss/GhezziBrian STW
D-Zug Produkte/D-Zug.com
Old 01-08-2009, 07:04 AM
resident samsquamch
sand_man's Avatar
I believe it's 600 ft/lbs with a stock spring centered clutch disc.
-jeff
Old 01-08-2009, 07:09 AM
resident samsquamch
sand_man's Avatar
Stage two, which increases the pedal pressure, should come in at 700 ft/lbs.
-jeff
Old 01-08-2009, 07:10 AM
resident samsquamch
sand_man's Avatar
Also, buy the part directly from KEP. I paid $650 for the pressure plate, which is a direct bolt on for my application...no other conversion parts were needed. Ptrick Motorsports has the same part listed for $778.00
-jeff
Old 01-08-2009, 07:14 AM
mark houghton's Avatar
I've been running with a KEP stage one for over a year now. No issues, and all the positive benefits as already mentioned. So far it's been a good investment.
Old 01-08-2009, 09:24 AM
DSPTurtle's Avatar
A message from the way back machine... just an update to the drive-ability discussion (plus I have received a few PM's on this topic). I finally have something to complain about with this setup. I got the A/C working about a month ago and I started noticing that with the compressor engaged, while coming to a stop, the motor will in fact stall. I have a feeling that if I up the idle speed a tad this issue will go away since I set the idle and drove it mostly with the AC out of commission. As for driving it in traffic, or having to slip the clutch, none of that is an issue. So anyone who tells you that they heard second hand that it makes the car harder to drive (930's are already the most challenging animals on the planet) is telling a tall tale worthy of a swig of whiskey.
FWIW, I have done ltw flywheels in two other cars and both had the exact same stalling issues with the compressor engaged... popping the clutch in 2nd gear becomes second nature
JB - BreitWerks
www.breitwerks.com
321-806-8664
Old 07-07-2009, 01:21 PM
lin7310948's Avatar
i have a kep stage 2 pressure plate and an organic racing disc. per my notes the stage one pressure plate is good for 536 ft lbs torque and the stage 2 pressure plate is good for 650 ft lbs torque. i think that the stage 3 is perhaps rated at 700 ft lbs torque but might be hard to slip for street cars.
69 bronco..... 91 mustang ssp santa clara county sheriff's office ...2017 focus rs tuned on 93 400 chp
Old 07-07-2009, 05:04 PM
I installed an AC vacuum solenoid from an old L-jetronic BMW.
It installs so it bypasses enough air around the throttle body to raise idle speed about 300rpms. Electrical hookup is to the AC compressor 12 volt supply wire.
With it installed the solenoid opens when the AC compressor is turned on and lets just enough air bypass the throttle body so the idle speed doesn't drop and remains strong when the AC cycles on. Works perfectly
That might help out your stalling situation.
I got the vacuum solenoid out of an early eightees 6 cylinder BMW with L-jetronic fuel injection in a junkyard.
Around '84 BMW started using motronic injection and this vacuum solenoid is not used anymore.
A new one could probably be bought here in the BMW section but it's probably expensive.
Old 07-07-2009, 05:20 PM
