LinkBack Thread Tools Rating: Thread Rating: 1 votes, 4.00 average.
clack noise from the engine when I hit the gas
Hi got a clak noise when I rev the engine , like some valve is opening up.
is this normal?
Old 07-20-2009, 06:46 PM
ewave's Avatar
Sounds like the EXACT problem I am mentioning in my thread!
Pop off valve clanking...Low Boost at High RPM
Paul
2001 CLK55 AMG, 1987 911 Turbo Look, 1997 Viper GTS.
Old 07-20-2009, 06:48 PM
mark houghton's Avatar
is this normal?
99% certainty it's the silicon rubber gaskets on the end caps of the boost recirculation valve piston housing. They harden over time and don't cushion the piston as it returns to it's stop. Every time you step on the gas, or get off the gas, that piston will move in response to the vacuum (or lack thereof). You'll hear it when sitting still at idle, with a sudden tromp-and-release of the throttle.
Our host has the gaskets for a pittance, and it's just a couple hour job to replace them. Or, live with the noise. Only when the seals get so bad as to leak boost would you be forced to replace.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ.
Old 07-20-2009, 07:59 PM
exactly the noise I have
where is this "boost recirculation valve piston housing."
Old 07-20-2009, 08:09 PM
A930Rocket's Avatar
Old 07-20-2009, 09:12 PM
any other parts I need to replace while I am removing it?what else should I do while there?
Old 07-20-2009, 11:11 PM
beepbeep's Avatar
Howto:
Changing 930 dump-gaskets, pictures galore
Thank you for your time,
Old 07-21-2009, 08:39 AM
great write up . once there is there a way to test the "gold disk"acell valve I think?
Old 07-21-2009, 09:20 AM
Originally Posted by beepbeep View Post
Yep had same problem on a 89 930 i had!
SP Autobahn www.spautobahn.co.uk
Porsche inspector for Peter Morgan UK
http://www.porscheinspections.com/
"92" 964 turbo,Modified and recently rebuilt using all ARP hardware..
Purpose built fuel controller set up to acheive perfect fuel curve on CIS inj.
Old 07-21-2009, 09:35 AM
Send a message via AIM to Chuck Jones
I also had the same problem...not a clack....but more of a tick-tick as you tap the accelerator.tue rubber gaskets fix it just fine....relatively easy DIY. It doesnt' really hurt anything, just an annoying tick=tick.
1987 factory Slantnosed 930 Cabriolet/Guard's red
2002 Midnight Blue 996TT X50
1999 Iris Blue 996 (Dash fire burned and totalled 9/07)
Old 07-21-2009, 11:07 PM
