clack noise from the engine when I hit the gas
Hi got a clak noise when I rev the engine , like some valve is opening up.
is this normal? Thanks |
Sounds like the EXACT problem I am mentioning in my thread!
Pop off valve clanking...Low Boost at High RPM
Paul 2001 CLK55 AMG, 1987 911 Turbo Look, 1997 Viper GTS. |
Our host has the gaskets for a pittance, and it's just a couple hour job to replace them. Or, live with the noise. Only when the seals get so bad as to leak boost would you be forced to replace.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ. |
exactly the noise I have
where is this "boost recirculation valve piston housing." Thanks |
any other parts I need to replace while I am removing it?what else should I do while there?
Thanks |
Thank you for your time, |
great write up . once there is there a way to test the "gold disk"acell valve I think?
Thanks |
Yep had same problem on a 89 930 i had!
SP Autobahn www.spautobahn.co.uk Porsche inspector for Peter Morgan UK http://www.porscheinspections.com/ "92" 964 turbo,Modified and recently rebuilt using all ARP hardware.. Purpose built fuel controller set up to acheive perfect fuel curve on CIS inj. |
I also had the same problem...not a clack....but more of a tick-tick as you tap the accelerator.tue rubber gaskets fix it just fine....relatively easy DIY. It doesnt' really hurt anything, just an annoying tick=tick.
1987 factory Slantnosed 930 Cabriolet/Guard's red 2002 Midnight Blue 996TT X50 1999 Iris Blue 996 (Dash fire burned and totalled 9/07) |
