Prime of turbo
Could someone tell me what fuse or c/b to remove on a 92 turbo to kill the fuel pumps to allow for primming a new ball bearing turbo prior to start up ? Thanks
I just pulled the coil wire.
I thought about doing that 911st but I would have fuel squirting into engine with the pumps running. I guess I could look @ fuse panel cover and it might tell me what one controls the pumps .Just thought someone would know which one does so on a c2 turbo. Thanks
If it has an overboost sensor on the intercooler like a 930, pull the spade terminal wire off of it and the fuel pumps won't run.
6th fuse from the back and the two rear most relays run the fuel pumps on a 911/930, but I think they may have modernized the fuse panel and changed all that in the 964. |
Thanks J
Brilliant my a$$. I did that and as it turns out the battery was so dead that it wouldn't turn engine over to prime the turbo. I charged it and spun it over to prime the turbo and hooked the wire back up and the engine dosent hit a lick! Could I test the fuel pump relay by removerng it and installing a jumper wire between terminal #30 and terminal #87 , shouldn't both pumps come on ? I might have upset something on the alarm system as the radio doesent come on also.
Since your radio is also dead, that's a vital clue to look elsewhere I would say. Simple but obvious question: How clean and tight are your battery connections, and the ground strap under the car connected to the transmission? And/or, the connections at the starter itself?
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ. |
Since your radio is also dead, that's a vital clue to look elsewhere I would say. Simple but obvious question: How clean and tight are your battery connections, and the ground strap under the car connected to the transmission? And/or, the connections at the starter itself? By your term "the engine dosent hit a lick!", what do you mean by that? Won't turn over, or won't start up?
C2Turbos do not respond well to low battery's from what I remember.
I think my alarm would go nuts when I would hook up a new battery. It took somthing like locking and unlocking the passanger door to reset it but I am not sure it that is correct. The worst thing that ever happened was burning out the 69EZ ignition module. Brutally expensive but I found a used one and was back in business. |
Metal Guru
Pull relay R 61, which energizes the fuel pumps.
Paul B. '91 964 3.3 Turbo Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb |
I know pulling the overboost wire off had nothing to do with the issue I am having,just kidding with J Fairman, and venting flustration after working 2 days installing the new GT Turbonetics turbo and keeping it all stock looking with everything in original location . Then when I installed the intercooler I didn't have it alligned just right and tore the red o-ring that seals it to the throttle body. Then the battery was dead ,as I did not have the battery maintainer pluged in good @ cig. lighter. And then it dosent start. I will have to read up on the alarm system as how to make sure it is not keeping it from starting. Or it could be somethiong as simple as a leak between the intercooler and CIS. Looks like I have another day to kill. I think I will jump the 61 relay terminal 30 and 87 and make sure the pumps are running and try to start again then go from there . Thanks
