Where to find "test pipe"?
I believe this 87 930 has the stock cat attached to an aftermarket muffler. And it looks very tired. If it had an air pump it is long gone. I was thinking it might be a good idea to get this lump out of there.
I noticed that the GHLs are not available on Pelican. Is there another source? I searched and did not see any threads. Any body have a used one? TIA
erik.lombard@gmail.com 1994 Lotus Esprit S4 - interesting! 84 lime green back date (LWB 911R) SOLD ![]() RSR look hot rod, based on 75' SOLD ![]() 73 911t 3.0SC Hot rod Gulf Blue - Sold. |
I gave one to rarlyl8 a few years ago when he was looking at testing some. Check to see if he still has it laying around the shop...
JP 86 930/4 tribute beasty 81 sc beach beater ‘55 Belair ‘40 Ford pickup Last edited by rsrfan; 10-29-2009 at 04:34 PM.. Reason: syntax |
Thanks JP
I was thinking about sending Rarly8 a note. I found one at ****** for $250.....not bad..but for a piece of straight pipe....is there more to it?
If you're going to toss your CAT (good idea, by the way, it will make a huge improvement in your performance), then why not spend the money instead on a muffler that will bolt up directly to your turbo, like most aftermarket muffs do. There would be no need for a test pipe.
To me, the "test" pipe is an excuse to run without a CAT, and an easy way to put the CAT back on for yearly emissions testing. If that's the case for you, then buy a new CAT and a test pipe.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ. |
$250 and it's yours....
Here's a test pipe..
Then I built a straight pipe from a local autozone for less then $20 bucks and another ~$10 for an exhaust tip.. BTW - I sold my GHL because I wasn't happy with the finished product. The dual tips were not even. So what I did was make my own single outlet and bought a different valance. Much better....
Bill 997.2 |
I like the idea of a muffler that goes right to the turbo...and a Zork tube but that may be a bit anti social.
Thanks again!
Crotchety Old Bastard
The cat bypass tube will not do as much for performance as a free flowing muffler.
I do have JP's pipe but the air injection tube is mangled. Used it for testing.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
If you can swing it, get a new muffler assembly. While the test pipe will help, the stock muffler is restictive and VERY heavy. I hear Rarly's are the bomb...
JP 86 930/4 tribute beasty 81 sc beach beater ‘55 Belair ‘40 Ford pickup |
This actually has an after market muffler...but its big and heavy. I think it is a Remus. I am going to try to swing the Rarly option, he is almost local.
If anyone's interested, I have an old B&B twin outlet 930 muffler I'm tired of looking at.
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
can you send a pic? does it bolt right to the turbo?
