Registered Driver
Helmsy's Avatar
CDI Electrical Question. Please Help!
Tried to start the ol girl today and it wouldn't fire.
Fuel is good as well as the spark from the coil.
After hours of troubleshooting I found the Red wire/ white stripe to the CDI (I have an msd) has no switched power anymore.
From wiring diagrams it looks like it comes from the alternator and isn't fused??? Is this correct?
Could the alternator be junk or could I just tap into a different switched source for the msd and do without the red/white wire??
Ben
'85 930 - Black on Black
'95 993 Turbo - Silver
Old 11-17-2009, 02:32 AM
Registered Driver
Helmsy's Avatar
Does anyone know where the CDI gets its switched power from?
Ben
Old 11-17-2009, 02:47 PM
Wo ist die Rennstrecke?
DonE's Avatar
I don't know your setup, but I get my switched power from the front of the car - nothing in the engine compartment. Also, make sure it gets 12v during cranking too. Some switched power sources drop in voltage while the starter engages then goes back to 12v. That'll make you chase your tail for a while.
Old 11-17-2009, 04:45 PM
A930Rocket's Avatar
You have an MSD correct? It should have a two red wires. One thick and one thin. The thin is switched power. Can you not follow where it leads to?
Old 11-17-2009, 06:14 PM
Registered Driver
Helmsy's Avatar
Not sure if all are wired the same but here goes.
The red wire (mine has a white stripe) which used to go to the original CDI (in the 6 pin plug) is switched power. I used this for the switched power for my MSD through the 3 fuse panel.
I found that the wire which provided power to the CDI comes from the front of the car via fuses but also via the delay relay in the rear. I removed the realy and jumpered the terminals and bammo the switched red/white wire works again.
Guess I'll need to buy another delay relay.
Thanks for the help guys.
Ben
Old 11-17-2009, 07:03 PM
