Studs on 89 930???
Hi all
slowly preparing for top end rebuit .
Is there a problem with engine studs on my 89 930? Or the problem were for the earlier divlar?
Old 11-02-2009, 04:30 PM
After the next project
x98boardwell's Avatar
Input
ertech,
Other than the G50/50 on your 89-930 you should still be dealing with the Dilivars as well. I have an 87 and just replaced all mine during a rebuild with steel studs. I would do the same if you are rebuilding (even just the top end) since you will be right in that area.
I believe the height is 135mm long from the base. I can double check if you need that info.
Bryan
Current cars: 2012 Cayenne TT, 1997 993TT, 1912 Buick Model 34, Audi S8, 1976 912E, 2016 Cayenne Diesel
Old 11-03-2009, 03:48 PM
totle's Avatar
Bryan, what brand did you use for the studs?
where did you buy them?
Old 11-12-2009, 06:33 AM
Ingenieur
x98boardwell:
Were any of your studs broken when you removed them? Did you ever use any kind of engine cleaner on your engine?
Old 11-12-2009, 05:15 PM
Studs
I purchased them from Walt at Competition Engineering. He is a great guy and he sells a great product. They are also less expensive than ARP but the same quality.
"Competition Engineering - Expert Porsche Machining for 44 years"
If you call him, leave a message and he will call you back within a day or so.
Best of luck,
Bryan
Old 11-12-2009, 06:18 PM
