tj930's Avatar
Wideband AFR sensor location
Guys,
What's the consensus for locating the sensor's boss on the exhaust system?
On PET, the 964 turbo has the Lamda sensor located somewhere on the exhaust pipe the 'wastegate' is mounted. I've seen a couple of guys here position the sensor on the top of the turbo-muffler coupling (but it's particularly hot here and I've seen some relocate to the muffler's bottom pipe).
Which is reckoned to be best? (Does one need a heat shield to stop the sensor baking in the turbocharged-exhaust-pipe sun?)
Old 11-13-2009, 01:46 PM
tj,
The general opnion will pobably tell you 6-10 inches from the turbo outlet at the 2 or10 o'clock position and preferably with a heatsink and shield.
Also your configuration will depend on your exhaust system , zork or
muffler and tail pipe.
Cole
Cole - 80 930 "The Old Sled"
Mods: TurboKraft Custom IC, 934 Headers, GSX 61, Zork, Port Work, SC Cams, Air Mod Fuel Dist Relocated, Water Meth Injection, BL WUR, MSD 6530, Greddy EBC, Synapse Bov, Short 2nd & 3rd with 8:37 R&P, Wevo Shifter, Coupling, and Mounts, MTX-L SSI-4, Big Brakes, Rebel Coilovers, Bilstein Sports.
Old 11-13-2009, 02:18 PM
mark houghton's Avatar
+1 as Cole stated.
For my application, there was too short a space between the muffler and turbo outlet to get far enough away from the turbo and not cook the sensor. So, I installed mine in the tailpipe as close to the muffler as possible....probably 10 inches away from the tip. Works fine, the only risk being that at a standstill and stiff tail wind, you may get some ambient air getting in and causing a false high reading. But I haven't seen that happen.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ.
Old 11-13-2009, 02:46 PM
Happiest when Tinkering
gsmith660's Avatar
This where Innovate tech support told me to mount mine.
I get good stable readings and I also have a 2000 deg. heat shield on it.
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go!
76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3
76 Blazer also restored by me
Old 11-13-2009, 02:49 PM
tj930's Avatar
Thanks, guys - so, close enough to the action (but WITHOUT getting melted)?
Gsmith, my car's muffler is pretty similar to yours - I see that you've located the sensor nearer to the cold side of the turbocharger, but it's still going to be pretty, damn hot there! (I can see why a heat shield would be a really good idea.)
David and Mark - thanks and I hope you're both returning to full strength and peak physical condition very soon. ("Tiptronic?" splutter... cough.. Get well, Cole, and then help kick his behind for even suggesting such a thing! )
Old 11-13-2009, 03:01 PM
tj,
Innovate also makes a great heat sink for mounting to the bung. The EGTs on
a 930 are really brutal and sensors burn up fast without adequate precautions. I
ran my LM-1 hard wired in the car but only use it to power my digital dash display. When tuning or periodic AFR and system checking I reinstall the WB02 and run some data and then remove it. If your not doing track work that's the way to go.
Cole
Old 11-13-2009, 03:25 PM
gsmith660's Avatar
They also suggested the 1 inch bung I'll see if I have a pic with the heat wrap. I found one.
sjf911's Avatar
Yup, I've already burned up two sensors running them next to the turbo. One of my projects this winter is to get a bung welded on the pipe beyond the muffler. I have a RarlyL8 muffler so there is room on the right hand side where it will get more airflow and be away from the turbo completely.
Sapere aude
1983 3.4L 911SC turbo. Sold
Old 11-13-2009, 04:04 PM
A930Rocket's Avatar
^^^ +1. I've burned up several as well at the track. Happens a lot when I blast of out of the pits. It just goes into some error mode and it's no good after that. That's with a zork.
For the street, I need to move it to the outlet portion of the muffler like above and use my heatsheild.
Old 11-13-2009, 07:17 PM
Manassas, VA
lucittm's Avatar
I installed a catalytic converter bypass pipe for "test purposes only". I have already done the air injection delete so I don't need this threaded fitting. With some delicate drilling and tapping, I was able to get a WB02 sensor threaded inside the male M22x1.5mm fitting (so now it is a hermaphrodite fitting?) midway between the turbo outlet and the muffler. Here is a picture of the fitting on the bypass pipe:
Mark
1991 964 Polar Silver Metallic Turbo Coupe
Old 11-13-2009, 07:41 PM
tj,
Thanks for the kind words and the "OLD ONE" is just great.
Cole
Old 11-13-2009, 09:07 PM
Turboo934's Avatar
What if you're running a zork?
Old 11-13-2009, 09:14 PM
gsmith660's Avatar
use a heat sink
Old 11-14-2009, 08:06 AM
g,
Great idea with the heat sock, Nice install.
Cole
Old 11-14-2009, 02:26 PM
gsmith660's Avatar
thanks time will tell if I did good
Old 11-14-2009, 05:10 PM
Sensor placement reply
I attached my sensor at the end of the muffler and it is connected to a XD-16 gauge on the dash. This works well and was straightforward to connect.
Old 11-14-2009, 10:32 PM
When I bought my NGK wide band setup they recomend installing the 02 sensor 10 times the dia. of the exhaust system from the end (ie. 3' pipe = 30"), to insure false readings from air being sucked back in the end.
Old 11-15-2009, 05:38 AM
gsmith660's Avatar
I'm thinking I will mount a temp sensor on the heat shield and run it then move it inside and see how hot it gets if it warm enough I might do this soon.
Old 11-15-2009, 08:31 AM
tj930's Avatar
Originally Posted by john930 View Post
That's a very innovative approach - I hadn't considered that!
Old 11-15-2009, 11:29 AM
Thanks, I have an LM-2 and can connect it to this and can log AFR's, boost and rpms.
Old 11-15-2009, 11:55 AM
