strange electrical problem
Hopefully someone has heard of this.My reverse lights don't work,fuses good,bulbs good,I can put 12v to the grey/brown wire at the switch and the lights come on.I think my problem is the supply?Lastly when I put it in reverse the druck pressure goes to "0".....Thanks for listening. 87 930 in case I forgot to mention..
What about the switch at transmission itself? Easy to check using Ohmmeter
Roland 930 Turbo '81 Too many modifications to list |
My guess is you have a bad switch.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ. |
ohmed the switch , its working properly,its new.
83 911 Production Cab #10
I've seen this before...
Speednut
I've seen a thread on this before (pressure going to 0 when reversing)... Unfortunately memory (and bladder) is like a sieve and could not find it if my life depend it on it. Should get a solution before the Sun rise in the East. J.J.
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
speednut..
Sounds like you need an electrical diagram. If you ask nicely in this forum someone should be able to help you out with a print. The oil pressure sending unit works on resistance and is not in the same circuit as your back-up lamps.
Thank you, HFR_Racer '87 930, 3.3 liter, K27 hybrid, Kokeln IC, Andial, B&B, Borla, 17" Supercups. |
I have a diagram,this is the strangest thing I've seen..I have never had an electrical problem that I have not been able to fix ,but makes no sense...........It's all most like someone has messed with it ! Some how connected wires wrong..
Registered Driver
Ben '85 930 - Black on Black '95 993 Turbo - Silver |
May not be your problem but there is something in common between the Oil Pressure gauge and the back-up light. Check entry # 6 & 8 of Oil pressure gauge pegged (ignore the title)
Thanks JJ911SC!! I think someone messed with it..Thursday I'll check that,betcha any thing the wires got switched..
Keep us posted...
Did you or someone work on your car recently? Or did I miss that in your post?
I just bought it wensday 11/4/09, the problems I'm sorting are the p.o.'s
I had a mouse take-up residence in my trunk who ate through the protective sheath of a 1.5" wire bundle. WIth your meter dropping to zero concurrent with the reverse circuit being activated, a wire diagram would help you look for areas where the two circuits are adjacent to each other. Might want to also begin looking around for evidence of vermin "residents", i.e. droppings, chewed-up carpet to make a bed, etc.
Hope you find the problem. Chip, Woodbridge, VA |
Thanks all , JJ sc911 , special thanks,the thread you sent me was what I needed.Someone switched the wires ,that caused the whole problem!Nothing worse than trying to trouble shoot something thing that someone else FORKED UP! MANY THANKS!!!!!!!!!!!!!!!!
One down, many more to solve...
A La Prochaine J.J. |
Banned
Ms. Jewelry (4)
[color=#1f3730][font=Times New Roman][size=3]cdcd[color=#1f3730][font=Times New Roman][size=3]erre[color=#1f3730][font=Times New Roman][size=3]ddee[color=#1f3730][font=Times New Roman][size=3]sssa[color=#1f3730][font=Times New Roman][size=3]kakak
