Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
smog removal problem...
Hi remove almost all the smog stuff from the top .how do you remove the pump? I already cut the belt.
and I left the spider in place but there is air being sucked from the part circled in red. is this normal?
Old 11-16-2009, 04:47 PM
mark houghton's Avatar
If you're going to leave the spider in place, then you must plug it at the end. If you've already cut the drive belt, then it should be a simple matter of unbolting and removing the pump. Mine was already gone (and in a box of parts) when I bought my 930, but it can't be a big deal to remove it I wouldn't think.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, stock everything else. The result of a massive Pelicanite good will fire recovery effort. Truely an open book, ready for the slippery slopes to modification.
Old 11-16-2009, 05:28 PM
