picked up my powder coating
fresh out of the oven.... Guy did a nice job, 10 day turnaround and VERY reasonably priced. Does ceramic jet-hot style coatings on headers and engine components and as well.
82 930 Pearl White 3.3 964 cams, K27 HF, Kokeln, fuel enriched, IA fuel head mod, wur mod, crankfire, 2X plug, Aase worked heads. 1bar, GHL, zork, 23/33 bars, low, loud |
Stuff looks great. what did he do with the edge`s of the fan blades? I know some people were having isues with the powdercoating being to thick on the end`s of the blades and they would rub on the fan housing.
Tim 87 930:G-50 5 Speed, Powerhaus Headers, K-27, Garretson Intercooler, RarlyL8 exhaust and 1 bar boost.... Gone: 85 911:Wevo shifter,full adjustable suspension,bigger torsion bars,Carbon fiber hood,930 brakes and rims. |
Ummmm. Powdercoating! Looks great.
I need to get my fan and lower valve covers done, as all else was done with the rebuild. Got one local guy that does ok. |
E-85 sippin drunk
Looks good...
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk |
they were taped off, no clearance issues at all. He also masked the backside of the valve covers. Altogether very clean.
almost better than porn.
Brian Enjoy Life ... Eat out more often ! |
Thanks, I might send him mine when I`m ready.....
beancounter
Looks nice...are you rebuilding?
While my engine is apart, I have had my entire engine tin powder coated...looks brand spankin' new now.
Jacob Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690 Past: 2009 997 Turbo Cab / 1979 930 |
coked oil in the spray bars toasted two rockers and cam have provided the perfect opportunity for adding the twin plug heads that've been sitting on the kitchen counter since 2005...
Isn't funny how the damnest stuff gets our rocks off!
RGruppe #180 So many cars.. so little time!! |
Ask for Dave, I told him I was going to post the pictures he said he loves to do this kind of work!
Sawheat!!!!
Just sent my fan to Dave I will post pic`s when I get it back. Slyguy did you get your`s back together if you did please post some pic`s.....
Tim, technically the motor is together... It's gonna be hot looking with the powder coating. Realistically just got my Electromotive coil packs from being spec'd out, have to pull the oil tank (had a coke clogged spray bar which brought me to this point), install the LM1 and re-tune (probably the most tedious of the tasks...) All in time for swimming pool construction season right!
Tom
tom is that what you do? build pools? ive been doin it here in so fla for almost 15 years and its been a slow start with our freezing winter we had down here good luck!
Looks good Tom!!
Good color combo. After looking at many here, I decided that the silver on black is one of the best, so I did mine like that. I used gold for the pulley.
1979 SC, Slant nose wide-body cab conversion. AEM Infinity EFI, COP, supercharged! |
Yeah, been building since the late 80's. Had a couple sunny 60 degree days and the phones been ringing pretty good. Pretty sure those 500 pool summers are a thing of the past, demographics are shifting up here in the North East. Need it to hit 90 for about a week...
Bought a hot powder coating kit from eastwood.
Works very well. Done many parts on my engine while rebuilding. Fan, fan housing, valve covers, engine tin, intake manifold, front a-arms, spring plates, rear brake rotor shrouds while replacing rear wheel bearings + other small parts Really pleased with the kit.
Trond R. 1979 930: Garret GT35r turbo, EFI, carerra intake, Link EMS, custom GT2 cams, 98mm JE P/C, 964 crank (stroker), custom valves & ported (XtremeCylinderHeads) etc..etc.. 1972 914-6 GT replica project 1986 944 Turbo |
That's great to hear totle. I just purchased a used EW pro-Coat gun on ebay and I'm modding a 120V oven from single to twin burner and expanding the oven to 32X32X52 that way I can do everthing including the metal trim for the glass trim.
I had to take apart and clean the gun. Also put a few drops of kroil in the pressure swith. I could have just bypassed the swtich but its a good safety feature. |
