Sorry but you didn't read correctly , the 3.3 and 3.6 injectors are different part number . ( You can check on the PET) 3.3 T injectors are bosch 0437 502 017 / Porsche 931 110 225 00 3.6T injectors are Bosch 0437 502 057 / Porsche 964 110 235 20 3.6T injectors are flowing about 8% more fuel compare to the 3.3T injectors. The 1st and easiest way to get more fuel is to up grade the fuel pump !!
965 C2T / 1991 3.3 TURBO |
![]() Actually , I own a second set of injectors fuel lines. ( I've got it together with the 3.6T injectors) So I used this 2nd set to make all the tests ! . Thus I kept my original injector fuel lines on my car without any bending, moving or whatever which could have damaged it. You are 100 right, it is potentially dangerous to run a car with some fuel leaking !!!!
Again, great info.
8% more fuel compares to a 3.6 being about 8.5% larger than a 3.3. The 3.6 ran 32mm intake ports just like the 3.3. Probably so they could just use the 3.3 manifold. |
Great info from Thierry, again ;-)
