car is dead...
Was going to take the car out for a night on the town but when I went out and tried to start it.... nothing except a click. Headlights turn on, radio works fine, but the car will not turn over. Won't even try to engage the starter.
You can hear the fuel pump or something in the rear of the car whine a little and then shut off once the car goes from "on" to "off" on the ignition. HELP!!! Is it the CDI? Anything else that I can check? Just had the car out Thursday for a good 4 to 5 trips... shut down and start up each time with NO troubles at all. I have not tried jumping it as I need to go to dinner still, but have all day tomorrow to figure this out.
1996 Porsche 911 2013 BMW 335xi - Wifes car 2007 4Runner - 4x4 for Colorado snow Past: 1988 Venetian Blue 911 Targa, 1983 Black 930, 1984 Black 911 Coupe |
Sounds like maybe it is as simple as a starter that is on its way out. You have to jack up the back, and put a test light on small wire while someone tries to crank it over. It test light lights up, bad starter. If not, check wiring back to the ignition switch. Be careful being under car while someone is turning key. make sure you are in neutral
83 911 Production Cab #10
Probably the Starter Path
Chris
Hope you had a nice dinner and you were able to fall asleep... I'm no expert (usual disclaimer) but your symtoms point toward a starter problem as it won't turnover while the batery seem to have power.
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
Update....
Checked it again one last time before heading off to dinner and now hear a sound coming from the ignition area when it sits in the "on" position. Makes me think that it is the ignition, crossed wiring, or possibly the starter is bad, and because it is bad it is sending a extra current back to the ignition???? Alright, off to dinner, and DRINKS.
I had this same problem on my turbo. As it turned out there is a heavy black cable attached to the positve terminal (assuming it goes directly to the starter) of the battery and it was loose....tightened and all is good.
Just a thought..........
1988 Porsche 930 Factory Slantnose 2011 Porsche Panamera Twin Turbo 1974 Porsche 914 2.0 Phoenix Red 1965 Shelby Cobra Replica- 428FE 2007 Mercedes SL55 P30 Package |
Wo ist die Rennstrecke?
Porsche Axiom - look for the simplest solution first...
Sounds like my car....turns out I have a battery drain that is intermittent.
I can drive, park and start-up 7 days later, sometimes I drive, park and have a dead battery 2 days later? I just put a battery tender on it and the problem is now masked
Rod... 2010 - 997 PDK, Black on Black, Daily driver. 1987 - 930 Grand Prix White, Not looking for crazy HP, just harmony! |
Take off both the positive and negative terminals on the battery and clean them. 99.0% of the time, symptoms like yours are the result of poor battery or ground connections. You get the click of the starter solenoid, but due to the poor connections there aren't enought amps available to turn the starter over. Plenty of voltage for low-amp things like CDI, etc.
If that doesn't fix it, be sure to crawl under the car and check the ground strap where it connects to the tranny, plus the ground strap from the battery where it connects to the frame.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ. |
turn the ign swith on, take a screwdriver, crawl under the car, lay it across the solenoid and starter terminals to manually jump them. I if it fires, then you either have a bad solenoid switch or ign switch, or...loose wires on either. Oh, make sure the car is out of gear. Done this many times on old 911's.
Tim 1986 930 Gone:71,2,4 914's, 70T, 71T(RS),77S |
Yasin
Ole Skool - wouldn't have it any other way |
Crotchety Old Bastard
I use a remote starter switch. Much safer and has many uses like bumping the engine to Z1.
If you jump the starter and your car starts then you are looking at the ignition switch or solenoid.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
Bad battery?????????
Infidel
I thought if the solenoid clicks but doesn't turn the starter, and then you bridge the solenoid with a spanner or screwdriver etc, and the starter then works, it points to a bad solenoid?
Jonathan. 87 930, 993 turbo engine, RS Tuning 520PS/515lbf-ft, Arrow Rods, ARP hardware, Solid lifters, G50-50, RS Flywheel, 890nm Sachs clutch, RSR coil overs all round, 993 C4 calipers front, 930 fronts on the rear, Ruf Speedlines..... Old 540 BMW, XB12S Modified, for being a total hooligan
Guys these are all great ideas.... now that I am thinking about it the car just serviced on Thursday and I am betting the battery cable is loose. Makes sense. I will check there first.
As for jumping the starter, I did this all the time on an old Mustang. I have pictures of me standing in the engine bay while the V8 is running.... so much room in there.
Alright... the battery cable was hardly on there, but after getting it cleaned up and back on nice and tight. Same results.
I put the key in, turn it to on and get some noises from the ignition switch itself. Then I turn the key and get a click, and everything loses power... I am going to the ignition switch next. The strange noises when in the on position makes me think that there is something wrong here.
Try a new battery...or jump it...it really sounds like a bad battery.
Don't think the worse.. as many have already said and I agree .. Battery!
Clean your cables, charge battery, reconnect and make sure everything's tight... crank and go have fun!
RGruppe #180 So many cars.. so little time!! |
Had something that sounds like this on a 71 911. It turned out to be the non-electrical portion of the ignition switch. The lock and tumbler portion of the switch would no longer turn the rotory switch far enough. Good cranking power but no fire.
