help with short 930 tranny helper spring
I have a rebuilt, short bell housing 930 that I purchased. It has the throw out lever and the adjustment lever, but no helper spring. I can not find any good pictures of what this assembly looks like for a circa 1977 930 tranny. Can someone upload a photo?
The diagrams on our host's catalog are all for 915 throw out arms, which seem to have many more parts (bearings, clips, washers, etc). The pin that sticks out of my throw out arm (and the one on the tranny) are smooth. They don't look like any sort of clip goes on them to help hold the spring in place. Below is a photo of the throw out arm.
Also, there is a notch in the adjustment lever for a spring (I think), but there seems to be no place on the under side of my tranny to attach the other end. I have uploaded a photo of the underside of the tranny below as well.
Any help would be greatly appreciated!
Notice the pin on the arm, what holds the helper (omega) spring on?
I purhcased this spring from Pelican, but I think it is for a later 930 tranny.
1984 930 Cab LS6 Conversion
www.kingham.com/porvette/
Old 04-04-2010, 09:20 AM
Forced Induction Junkie
WERK I's Avatar
Here are a few shots from a '85 930.
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 04-04-2010, 09:30 AM
A930Rocket's Avatar
Looks like you have the same 930 parts as my 87, except for the pin. Here's another angle that might help.
You'll need to position everything and then load the spring.
Well Heck! I just installed IE 8 and now I can't upload a picture. Look under my screen name or do a search.
Old 04-04-2010, 09:38 AM
Thanks Dave, but I think the newer (long bell housing 930) throw out levers are different than mine. Your's seems to have some sort of bolt on the end and I'm guessing a receiver for the omega spring, mine just has a pin.
Old 04-04-2010, 09:48 AM
Here is an omega spring listed on our host's catalog that says it is for a 76-77 930, it appears wrap around the pins. Perhaps this is the correct part, but isn't there anything to hold the spring in place?
Old 04-04-2010, 09:52 AM
lin7310948's Avatar
trans
i do not have an omega spring on my transmission. it is a shortbell 76-77. i do not know if those models used the helper spring. i do have an omega spring on my 78 930 however.
69 bronco..... 91 mustang ssp santa clara county sheriff's office ...2017 focus rs tuned on 93 400 chp
Old 04-05-2010, 03:33 AM
no omega spring
Hi lin7310948, any chance you could send me a picture of your setup?
Thanks, Mike
Old 04-05-2010, 04:21 AM
Here are photos of my 1977 930. The factory repair manual says 1978 and on are different from the earlier 930s
Anthony @ Voitureltd Bayside WI.
Old 04-05-2010, 06:32 AM
lin7310948's Avatar
transaxle pic
mike, not as clear but the best i could get without jacking the car up!
Old 04-05-2010, 07:46 AM
Happiest when Tinkering
gsmith660's Avatar
I added the small spring to my clutch (915 not 930) and also did not have any thing on the tranny to attach the spring so I drilled and tapped a hole and put a bolt in there my clutch arm had a hole for the spring in it
Old 04-05-2010, 07:48 AM
Tags
early 930 helper spring
