Tinkering Pays!!
Oil Hose Repair??
The fitting I circled is leaking... It leaks a drip per minute... Can the hose be repaired, or does it need to be replaced?
Or, should I just go ahead and get two new hoses with new style fittings - - maybe something I can make up myself??? Anyone know what type of shop specializes in this? Thanks in advance...
LIVN80S - - Red '79 Porsche 930 Steel Slant Nose Conversion [in 1987] w. 46k miles 3.3L; 964 Cams; K27HF @ 1.0 BAR, with Garrettson Intercooler; Rarly Zork; CIS Flowtech Fuel Head & BL-WUR. Last edited by mooney265; 03-13-2010 at 04:29 PM.. |
Hey mooney you may be able to make an AeroQuip braded hose it would not be too difficult, i had one made for my turbo oil feed line. They can braze those banjo fittings onto some AN fittings then insert them into a braided line. I think it was about 70 dollars to make my hose.
http://whrrl.com/place/5246561/eaton-corporation---aeroquip-products-sales-new-orleans http://www.aeroquip.cc/ ![]() ![]()
1992 968 2011 Cayenne 2007 997 Turbo 1991 964 Turbo 2005 955 Cayenne Last edited by boeing 717; 03-13-2010 at 07:14 PM.. |
answer is yes to everything, just how much you wanna spend.
The scavange oil circuit is low pressure, there's no restriction other than the oil filter. You could remove that fitting by carefully cutting it not too deep with a dremel and peeling the rest off with needle nose pliers and then replace it with a hose clamp snugged down on the hose. The banjo fitting has a barbed nipple inside the hose and is reusable if not it's not cracked making the oil leak. Unless the hose is in bad shape it shouldn't leak. |
Tinkering Pays!!
LIVN80S - - Red '79 Porsche 930 Steel Slant Nose Conversion [in 1987] w. 46k miles 3.3L; 964 Cams; K27HF @ 1.0 BAR, with Garrettson Intercooler; Rarly Zork; CIS Flowtech Fuel Head & BL-WUR. Last edited by mooney265; 03-13-2010 at 08:30 PM.. |
Tinkering Pays!!
LIVN80S - - Red '79 Porsche 930 Steel Slant Nose Conversion [in 1987] w. 46k miles 3.3L; 964 Cams; K27HF @ 1.0 BAR, with Garrettson Intercooler; Rarly Zork; CIS Flowtech Fuel Head & BL-WUR. |
elvision930
you guys sure are handy.
Tinkering Pays!!
How do I determine what size [AN-Size] this banjo fitting and hose are??? Where do I take the measurements?
LIVN80S - - Red '79 Porsche 930 Steel Slant Nose Conversion [in 1987] w. 46k miles 3.3L; 964 Cams; K27HF @ 1.0 BAR, with Garrettson Intercooler; Rarly Zork; CIS Flowtech Fuel Head & BL-WUR. Last edited by mooney265; 03-13-2010 at 08:55 PM.. |
1992 968 2011 Cayenne 2007 997 Turbo 1991 964 Turbo 2005 955 Cayenne |
After the next project
My opinion
Mooney,
Where exactly is the leak? If it is leaking where the black hose first feeds into that fitting then the fitting will need to be replaced. If it is leaking at the seam on the fitting (like it is cracked) then you may be able to fix that pretty easy. If it is a crack in the fitting then I would take that hose to an air conditioning shop and have them fix it. They can pressure test the hose, determine where the leak is and then braze (not sure on spelling) the area to fix the leak. Otherwise, I would go the A/N fitting route. I have used Pegasus racing and they have the Metric - A/N adapters that you may need to connect the lines but their A/N fittings are not "true A/N" fittings... they connect to the hose differently and seem to be lacking some quality. I still used them and have been happy but when I went to a race shop locally and purchased true A/N fittings I could tell the difference in a second. Here are a couple shots of what I have. I know this is different than what you have but it may give you some ideas. I used A/N-16 lines and fittings. The curved one is a 150 degree adapter and you can see the blue metric/a-n adapters as well. The two fittings (45 angle) that feed into the oil cooler are true A/N fittings... I had to buy the angled ones to clear my fog light on the passenger side. Best of Luck, Bryan ![]() ![]()
Current cars: 2012 Cayenne TT, 1997 993TT, 1912 Buick Model 34, Audi S8, 1976 912E, 2016 Cayenne Diesel |
Tinkering Pays!!
Off to the St. Patti's parade... Will run the engine and test for leaks later tonight. If all well, bumper back on and back on the road!! Thanks - - I have learned a little more about AN-fittings in the process...
Tinkering Pays!!
Here are the pics... It's not super pretty, but should be very effective... Thanks again!!
Heck it looks as though you might just be able to clamp a braided hose right onto that banjo fitting.
Those hoses may have been made in europe so the size is probably metric and you match that to something that fits or the closest AN (army navy) size.
Tinkering Pays!!
So, that's what AN stands for.... would have never guessed that!
![]() I have most of the Metric oil hose fittings like these....... ![]() ![]() And make replacements for originals like this... ![]() I also make up custom oil lines like these..... ![]() done for a concours winning 914-6 GT. I also do metric fuel hose assys and have adapters for Metric to AN. Please no PM's, email me for info. Len at autosportengineering dot com
