-   -   K27 Turbo Bracket Differences? (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/536927-k27-turbo-bracket-differences.html)
jcc911 04-15-2010 08:53 AM
Is there a difference between the brackets for the 930 and the 965? Or I should say for the 3LDZ and the 7200?
The reason I ask is that I have one of each. One from a 92 965 and the other I bought from Quentins 930.
When I quickly looked at them last night they seemed the same.
I plan to sell one of them and I want to make sure I describe it corretly.
Thanks, Jeremy
WERK I 04-15-2010 09:20 AM
Jeremy,
The differences between the two are fairly subtle. The K-27 brackets have a section added to makeup for the offset required for the hot housing differences. I read from one of Brian's (Rarly8) that the newer brackets have the same part number for either 3LDZ or K-27. You may have one of those.
The pic below shows an earlier bracket from the factory that has the modification to support K-27's. (section highlighted).
http://forums.pelicanparts.com/uploa...1271348405.jpg
mark houghton 04-15-2010 11:04 AM
This was discussed just recently: http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/532475-k27-turbo-bracket.html
