AFD660's Avatar
RarlyL8 wastegate muffler
Just finished installing Brians (rarlyL8) wastegate muffler. After snapping all 4 studs then having to get them drilled out and replaced and then replacing the wastegate spring from a 1 bar to a .7bar, a 1 day project turned into a 1 week project. Damn life gets in the way.. lol..
Finally got to take it for a test drive after it sitting for a while. Well you know when the wastegate opens up now. Its not much louder over the zork tube, but adds a nice "extra" to it. LOL.. thanks again Brian for the excellent piece of engineering and welding.
I did a hasty job in painting the housing. I know i should have painted it while it was off the wastegate but my friend that helped me had to leave so we had to reattach it before he left. lol..
1984 930... Andial intercooler, GT35R, Zork tube, RarlyL8 wastegate pipe
Old 07-05-2010, 10:24 PM
Crotchety Old Bastard
RarlyL8's Avatar
Not much of a "muffler", ha!
Sounds like you had about every obstical possible. You should hear these with a stock muffler; pretty cool Jeckle/Hyde.
Old 07-05-2010, 11:25 PM
beancounter
jwasbury's Avatar
I've got the same dump pipe. It sounds good and it seemed to flow a lot better than the factory set up (on my '79 the wastegate was plumbed into the muffler).
Jacob
Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690
Past: 2009 997 Turbo Cab / 1979 930
Old 07-06-2010, 10:44 AM
Great photo. What kind/year exhaust is that?
Can someone annotate these letters for me with the correct names?
Here are my guesses:
A: Muffler
B: Exhaust pipe (why is it so long and go across the back of the car?)
C: Turbo peeking through
D: ? Turbo drip tank? If so who makes this one?
E, F: Heat exchangers
G: Wastegate "muffler"
H: Wastegate: factor? What year? Otherwise who makes it?
I: Heat exchanger outlet not connected yet, goes to passenger compartment?
Thanks!
Old 07-06-2010, 11:39 AM
Metal Guru
911nut's Avatar
A: Muffler
You scored 100%.
The drip tank looks like a GoingSuperFast one. I think I paid $80 for mine.
Paul B.
'91 964 3.3 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb
Old 07-06-2010, 04:43 PM
RarlyL8's Avatar
That system is one of mine.
The headers/exchangers are SSI,
Y-pipe is custom, RarlyL8,
Muffler is mine, RarlyL8, and exits the stock location,
Waste gate is OEM Porsche,
Dump pipe is mine, RarlyL8,
Oil sump tank is Asian.
Old 07-06-2010, 08:16 PM
