Fuel line part #'s and source?
I have fuel leaks at the swivel joint of the soft lines that connect to the hard line in the trans tunnel. Age and lack of exercise over the past three years is the culprit…
I've already stepped thru Pelicans offerings but can't find what I'm looking for. So, does anyone have the correct part numbers for these (hard line to rear fuel pump and hard line to fuel head)? Thanks, Lyall 1982 930
Lyall 82 930, 2500lbs 430hp Black, Black 85 944 ITS / SP2 racer 87 Carrera, stock, GP White, 03 Boxster S, GP White SOLD 73 De Tomaso Pantera, Grabber Blue 18 Alfa Romeo Giulia - Alfa Rosso Red |
Is it one of these?
Doesn't look like what I need, my lines have a swivel fitting and banjo.
Looks like I need to build these myself... Thanks Rocket! Lyall 1982 930
Someone here posted that they were making these now. I think he posted within the last week or two.
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
Do you have pictures? On my 87, it looks like the hose looks part number 14 from the fuel line in the tunnel, part number 33/36, to the rear fuel pump.
From there, it's part number 15, going from the rear fuel pump to the fuel filter. If you can't locate it, then maybe NAPA, an AC or Hyd shop can make new hoses with your old hoses/fittings. |
Here's a pic of the connection to the hard lines. Right one runs to rear fuel pump (approx 20"), left is the return from the fuel head.
p/n 33 does look like it could be the return line.
I think #33 is correct and here's a pix of the other line you want (#13). Can't find a part number yet.
