Sorry guys for the holdup but my daily driven car decided to give me all the problems it could have given me in one week but all well now. Two days ago I was going to check the car and then it didn't start! After several cursing there was 0 psi and ended up being just a relay, so I was now back to start but dies issue. I grabbed an allen wrench and turned the screw on the fuel head and didn't see a change. I was brave enough to keep on turning and about after 4 1/2 clockwise turns it was idling by itself. So it's back up and running.
Turbofrog
If your talking about the idle CO screw you need to push it down while turning and it only needs very small increments for big changes so I think you did not push it down enough if you made that big changes?
4 1/2 turns is a lot. It must have been WAY off.
The dyno run will get it dialed in and it will be interesting to see how it works out. |
Let's hope that's all it was. Now, either dyno it or find someone that can test your CO% out the tailpipe to get her dialed in to around 2.5-3%. You're not done yet, but almost there.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ. |
