sjf911's Avatar
Originally Posted by JohnJL View Post
Sorry for the hijack, but I am also running EDIS and have coil/plug wire issues. What EDIS coil are you running and what plug wires?
I used Clewett wires when I ran EDIS. OTOH, Boost Engineering sells EDIS coil connectors to convert Porsche wires.
Sapere aude
1983 3.4L 911SC turbo. Sold
Old 01-01-2011, 08:17 AM
Happiest when Tinkering
gsmith660's Avatar
Thanks for the ideas I think I have cold start pretty close now it's 23 deg. here and it fired and died then I had to crank for maybe 2 sec. to get it to start and it came up to 1600 rpm and stayed there no stumbling no backfires.
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go!
76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3
76 Blazer also restored by me
Old 01-01-2011, 07:22 PM
R.I.P.
drmatera's Avatar
yer gettin' it now. I also enjoy the learning experience of DIY EFI
Old 01-02-2011, 11:29 AM
gsmith660's Avatar
Tweaked a little more still died right after start tweak the after start enrichment a little more.
Old 01-02-2011, 03:19 PM
gsmith660's Avatar
Started it about an hour after the last start and it was smooth started, come up and idled, after about 2 min. (when I have ASE set to go away) there is a little bit of a stumble but not much if it starts good tomorrow morning then I will extend the ASE a little longer to give the motor a little longer to warm up when really cold.
Old 01-02-2011, 04:03 PM
gsmith660's Avatar
After much tweaking of the cranking pulse width and after start enrichment I have a motor that starts right up 3-4 cranking cycles and idles smoothly at 850-900 rpm after 2-3 min. all at a temp. of 25-35 deg. after sitting all night now we wait till spring to tweak the warmer settings. Thanks everyone for your ideas and help.
Old 01-03-2011, 05:23 AM
R.I.P.
drmatera's Avatar
the devil is in the details
the stumble coming off ASE may be cause the decay is too steep. Make the last bit of decay blend in very slowly
Old 01-03-2011, 10:43 AM
gsmith660's Avatar
With this ver. I don't have the option of altering the decay curve but when I started it this morning it started and there was no hiccups I just started it at 50 degrees and it struggled to start but ASE worked fine so I will bump up that cranking pulse width bin.
Old 01-03-2011, 10:55 AM
R.I.P.
drmatera's Avatar
ahh, gotcha.
Old 01-03-2011, 11:42 AM
Wer bremst verliert
JohnJL's Avatar
What were your overall enrichments for cranking and post-cranking?
I have to fine-tune mine on Adaptronic...the car never saw cold temps in Australia so we never bothered with cold start tuning before!
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 01-04-2011, 08:35 AM
gsmith660's Avatar
My base tune was way off for the conditions here but I got it from someone in a warmer climate so it makes sense, but here goes.
cranking pulse width went from 6.1 to 8.5 at 20 deg.
after start enrichment went from 12 to 125 at 20 deg.
Old 01-04-2011, 08:49 AM
