Will a stock 3.3 flywheel bolt to a 915?
I'm having an '87 3.3 installed into my '77 911s and the mechanic does not know which flywheel to order. The 930 did not come with one.
2000 Boxster S 2004 330ci convertible 1978 450 SLC 1924 Model T Ford touring Fleet of Ford Buses, Sedans, SUVs and Limos |
Not sure what the part number is, but I have an 84 Carrera with a 79 930 motor bolted to a 915 tranny. I would say yes.
John- 78 Slick Top 930 "Illegitimi non carborundum" |
I am starting to put a 3.3 into my 1974 911. I just had my 2.7 flywheel beside the one on the 3.3 I believe the turbo is 240mm for the 930 trans and the other one is 225mm for the 915 transmission. I am not 100% sure.
Brando
Just use one for your car. Needs to be the 9 bolt. Toys should be fine. Order the sachs sport though. You'll need some extra clamping force. It should fit your 225mm flywheel.
Brando
Toys meant to say yours. iPhone thinks it knows best when spelling.
Crotchety Old Bastard
I used the (225mm) 915 flywheel and a Sachs Sport Clutch on mine.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
Brian how does the 915 hold up with that power. I am planning to get rid of my 915 and put in the 930 four speed but they cost a bit more and along with the change of the shifter etc.
Thnaks Neil |
I ran a stock 915/61 for 10 years in front of a 300WHP 930 engine. No issues until I took it to the drag strip. While the tranny was apart I added the WEVO bearing retainer and a Carrera side cover. I put that tranny back in and built a Euro Carrera 915 with the same style bearing retainer and custom gears to facilitate more power that was anticipated with the addition of my headers.
The headers added 50WHP and 60ft/lb torque for a total of 350WHP. So far the tranny is doing fine. You will note that no trips to the drag races will be in this tranny's future.
Patrick Motorsports just sold me a $400 RSR 225 mm 9 bolt saying that I'd need it.
A SC 3.0 flywheel should work.
Send it back you don't need it. All the 915 parts will work and will bolt right onto the 930 engine case as it is the same as the SC.
Brando
If your flywheel is 6 bolts, you need one with 9 bolts. The 3.3 only accepts the newer flywheel. An sc would work for sure. I'm not sure but maybe the 77' is new enough that it got the newer flywheel. That year is right at the cutoff if I remember right. Maybe 76 was the last 6 bolt?
My Sachs Power Clutch was down to the rivets after 15,000 miles, and had probably never held the stock torque. Use a Sport pressure plate or better, like others have said. That seems to be holding up well (although I think I'm pushing my luck and am plotting for a G50.,.). Make sure everything is in good shape, so it'll stand up to the higher pedal pressures (I've broken/replaced about every external doo-hickey & bracket attached to the clutch in the last 5,000 miles). My mag case 915 looked pretty sad inside after 15,000 miles behind a 930. Whatever you use, you should make sure it's in as good shape as you can - and the later the 915, the stronger it is. If it breaks, it'll be bad. WEVO bearing retainer and an LSD are really good investments, as is the later side cover or a WEVO billet replacement. Internal spray bar kit on the gear faces is also useful (factory did that for all the racing boxes, as well as a cooler). If I were doing it over again, I'd use the exchange WEVO cases with the steel bearing inserts as well. No matter what you do, the 915 is the limiting factor with a 930. You get easily get to a point where you make more power than you can reasonably expect the 915 & axles to handle/stand up to for long and you get tired of babying it. But it's tough to give up the 5-speed and the short gears...
'77 S with '78 930 power and a few other things. |
Brando
Here is a good thread on the difference of all 915 models. I believe that the 76-77 mag case model to be the best one of all but it's the one I have so I choose to believe that. Read the graphs. Mag is lighter and doesn't deform the way aluminum does, still the typical upgrades are pretty much required for 930 torque. I have this mag trans axle and I still think it's wise to "baby" it. As Brian said, it's a good 915 (915/61) but they are meant for 200lb ft. torque. Look at what renegade hybrid has as upgrades, they typically run a lot of torque.
http://forums.pelicanparts.com/Porsche-911-technical-forum/332597-best-year-915-transmission.html?highlight=915
Turbo powa! 1977 911s. it's cool |
Brando
triguy, your car deffinately needs the newer flywheel. Yours won't bolt to the crank of the 3.3.
You could use any sc or carerra up to 87 flywheel.
I knew about the flywheel being different. I have a 74 915 with the small ring and pinion in it. I think it will be weaker under load. I am going to have to buy something so I am leaning toward the 930 tran.
One other question is the sach power clutch the same as the sport clutch? Thanks Neil |
The Sport clutch is the closest thing you can buy to an RSR pressure plate, I'm told. Mine holds 350 ft/lbs to the rear wheels, but the pedal pressure is at least 50% higher, maybe double. Just in the last month or two (after 15,000+ miles) I've had the splined hub crack on the adjustment lever ("never seen one fail like that before", quoth my wrench) and the cable bracket ("seen one fail before, but it's quite rare").
I ordered the RSR flywheel
