twin plugging question
when i pull the trigger on efi soon i have a question about twin plugging the motor i was planning on getting the lower valve covers drilled or finding a set already done. Should i just get a set of 964 lower valve covers will they work? or do they leak or something like that.
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's. 2019 Silverado 6.2L |
Navin Johnson
Get your exiting lower covers machined, while you are having the heads done..
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
yeah well a set of 964 valve covers costs about the same as getting the other machined and I already have a spare set of heads any way was planning on getting a spare set of valve covers also to minimize down time. so will they fit? what i was planning on doing was stocking up on all the parts as i could afford them. getting all the custom machine work done in advance so when i drop the motor I just check every thing and replace the stuff I already know will need work. Any unanticipated / unexpected things that show up will have to be solved then but it will be apart a few weeks not several months.
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's. 2019 Silverado 6.2L Last edited by Ken911; 03-19-2011 at 02:20 PM.. |
I don't believe the 964 ones fit properly. Best to machine your existing ones.
I just drilled out the 6mm stud holes to 8mm. I really like the o-ring style gasket.
so the holes are different sizes? or are the studs different?
Forced Induction Junkie
I think the valve cover stud alignment is different on the 964 cover versus the 930. There is a picture of both covers in Bruce Anderson's latest Porsche 911 Performance Handbook 3rd Edition on page 105.
Dave '85 930 Factory Special Wishes Flachbau Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P |
i only have the second addition one
Here ya' go....
yeah the holes look like they are in the same place as well they should be since the 930 and 964 cam towers are identical. so the holes are just smaller then?
Still inconclusive. The 964 photos above show the intake covers, while the 930 turbo covers are for the exhaust side.
I seem to recall the 964 cam towers are different than more common "901" cam towers. Contact Steve Weiner at Rennsport. He would know right away. ![]()
i am pretty sure the casting numbers on mine start with 964 not 901
You're right 930 instead of 901. Early cam towers to '77 were 901's.
I,m using 964 covers on 3.3 cam housings just need to make the stud holes larger. I,m also using the latest VW coil on plug and they fit realy well.
[QUOTE=turbo nut;5913234]I,m using 964 covers on 3.3 cam housings just need to make the stud holes larger. I,m also using the latest VW coil on plug and they fit realy well. Ok cool then thats what i'll do for my twin plug set up
Very nice. Which specific coils are these and how are you anchoring them?
Steve Sapere aude 1983 3.4L 911SC turbo. Sold |
2001 1.8T. I think the latest are rev. D . I bought 14 of them through the dealer with a discount they well under $20. They have a rubber piece that fits tight like the 964 wires. I don't use a hold down.
Should also note plugs with a 5/8 wrench size need to be used.
Nice!!been wondering about this setup instead of two 6 plug coil packs
Thanks turbo nut. Any more details on your motor (maybe there's another thread?) Looks interesting!
Andy |
Thread Tools | |
Rate This Thread | |
