fuel distributor hose question
Where does bigger rubber line attach to ? 77 930
1977 930,no mods |
Crotchety Old Bastard
That big rubber line with the zip-tie (whoa!) feeds your cold start injector.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
Good eye, those zip ties are not doing anything. Threw them on when i thought they were vacuum lines that slip off. Now I now they are high pressure. I figured out the bigger line goes to the fuel filter. Pretty easy to mix it up and attach to the fuel accumulator. Ask me how i know.
1977 930,no mods |
What happened to the 3mm CO adjustment stalk?
Are you sure about that?
There is a hole in the air flow meter housing where it would go and a mark on the side of the fuel head where it may have been. |
Maybe someone else with a 77 930 can chime in.
The fuel head does not have a adjustment stalk like the later heads. The adjustment screw sits below the the surface inside. Its a real pain to adjust CO. It looks like you are missing the cap head screw and seal the goes in the hole. Without it you'll get get a vacumm leak and a lean condition.
1983 911SC 1977 930 Turbo (again) 2018 GTS 2023 Audi A4 '74 914 '76 911S '72 911T '73 1/2 911T '77 930 Turbo (all gone) |
WOW, did not realize there was a cap for that hole. I can't find the part number for that from looking at the parts diagram. It may be part of the body. Maybe thats why there is no part number for it. I guess i could put a rubber plug in it ?
1977 930,no mods Last edited by dhg1337; 03-18-2011 at 10:25 PM.. |
surfpangea
I have a 77 and my AF adjustment hole is threaded it uses a metric allen head screw
MB CL 600 6liter V12 daily driver 86 Corvette Stage 1 Nos (sold) 78 911sc Targa (sold) 77 930 stock 3.0 gsf header ,borla exhaust,gt30 BB turbo, V-band, full bay IC,WMI, 46 mm Adjustable waste-gate,Zeitronix wideband, Intergrated Car pc, Winlog interface Beta |
1977 930,no mods |
Cool.....
