Question Ceramic Coating of Hot Side Housing - K27-7200
Has anyone determined the benefits or downsides of having the hot side housing of the K27-7200 turbo ceramic coated? I have my motor down and am considering this as there is a tremendous amount of heat back around the turbo. As an alternative, are the various material-based turbo covers effective?
Thanks in advance for any facts or experience any of you might have.
Toby Pennycuff
Toby Pennycuff
Dallas, TX
1979 930 Petrol Blue Monster
1968/1973 911S MFI #73 - Tweety Bird. 911 PCA Club Racer. E Prepared
2001 GT3 Cup #77 - O M G!
Old 06-02-2011, 08:11 AM
Turbofrog
smurfbus's Avatar
I don't see any drawbacks of coating or covers if you take care of the cooling when stopping after hard runs.
Old 06-02-2011, 10:06 AM
66cal912's Avatar
I spoke with one company that remanufactures KKK turbos, and they said the benifits of the hot side being ceramic coated are definitely worth doing. If you want the contact for the guy that has it done out here in California, PM me. You need to be sure the proper, High temp ceramic paint coating is used. As there are two grades, one good to around 1000 Degrees F. and the other good to 1800-2000 degrees F, and that is what is needed on Turbo exhaust, due to the high heat, from the backpressure. To get just the Turbo housing done its going to cost you around 150-200 I suspect.
Hope this helps....
I am getting ready to have all of my exhaust Ceramic coated, been meaning to get it sent out for a good month, but been to busy with other stuff and its prevented me from taking all the parts back off the car after fit check.... I suspect its going to cost around 400-600 to have all the pieces coated, and thats with the hook-up price, I was a bit concerned with holding all the heat in on the J pipe and fatiguing the metal, but I am going to go for it, as the reduced heat on all the other parts around the exhaust will be a big gain, and keeping more heat in the J pipe, will only help spool the turbo up... here is a few pics of everything prepped...
BP.
Old 06-02-2011, 04:02 PM
Infidel
JBL930's Avatar
Ceramic coating is always a good idea with a turbo........... Mate of mine, this edition of 911 & Porsche World, taking it to the extreme
Jonathan.
87 930, 993 turbo engine, RS Tuning 520PS/515lbf-ft, Arrow Rods, ARP hardware, Solid lifters, G50-50, RS Flywheel, 890nm Sachs clutch, RSR coil overs all round, 993 C4 calipers front, 930 fronts on the rear, Ruf Speedlines.....
Old 540 BMW, XB12S Modified, for being a total hooligan
Old 06-02-2011, 05:41 PM
Tags
ceramic coating , k27 , turbo
