Warm engine power loss between 3-4K 964 Turbo 3.6
My first thread: My 964 Turbo occasionally acts up when the engine is warm. When you slowly apply more throttle between 3,000 and 4,000 rpm, it suddenly starts to jerk and stops accelerating, even though the boost gauge on the dashboard rises to 0.7 and stays there. If you push the throttle hard, it pulls strongly as usual. However, if you don’t fully press the accelerator, the same problem occurs again. I have replaced Lambda control units 96561810301, acceleration enrichment 96561813102 and Turbo relays 96561813001.
I hope someone has an idea, and best regards, Philip |
a 1994 C2 turbo 3.6 uses a throttle valve switch. It is a fairly simple device. You should Ohm it out to verify.
IF you don't have the factory manual you can use Gronk or Chat CPT to give you a detailed ohm and debug procedure. Debugging issues like this is methodical and one step at a time If the throttle valve switch checks out and is adjusted properly move on to next component. next I would check WUR pressures especially warm then look for intake leak then measure fuel delivery at fuel head |
Crotchety Old Bastard
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
A faulty FPR might struggle to maintain the correct differential pressure during the transition from vacuum to boost. When you go to full throttle, the system goes into an open-loop, maximum enrichment mode which might mask the underlying pressure regulation issue, but at part-throttle/part-boost, the fuel delivery falters, causing the jerking.
| Tags |
| 964 3.6l , power loss , turbo , warm engine |
