Done both of the above. Booooooooring. German Supra. Want torque, response, and up to 650rwhp? Run GT28xxR turbos. |
Sounds like Albert is aiming for BIG (1000+) numbers though :eek: Each to their own... either way, I love seeing these unique configurations :D P.S: Chris, have you ever fitted GT28RS turbo's on 993TT heat exchangers? Is it an easy mod? |
Yeah, twin GT35Rs did 819rwhp without much effort.
Yes, we have done the twin GT28xxR on 993TT heat exchangers many times: Turbos & Manifolds Installed New Header Flange Comparison That 3.6L did over 700hp on MODE's dyno, later 645rwhp on Dynojet. Huge, wide torque band to work with. |
At what boost levels did you net those numbers? On pump fuel, or race? |
Think about what HP this setup would make at 8000 - 8200 RPM or just looking at the engine bay would make me excited. GT-28, GT-30, GT-35 use same V-band flange, I can do a swap in 2 hours. I don't try it I would never know twin GT-35R turbocharger would feel like.... 6 individual throttle body on my shelf should look better in the engine bay!!!!! |
At idle air blow like hair drier... |
0.63 A/R is a good size for TT's... you can go down to 0.48 A/R and it will be VERY responsive, BUT it will choke the motor at the top end and limit HP output.
All depends how you use your car ;) |
The problem with running a big compressor wheel is the exhaust turbine has more mass to get spinning, which = more LAG, but once it's get spinning, it can flow huge amounts of air.
Smaller compressor wheel = quicker boost onset = fatter torque/power band = more fun :D Chris, how does the boost characteristics differ between the GT28RS vs K16/24 or K16/16G in a TT configuration? |
Getting back to the original topic: A very nice looking car. Do you have any specifications on the turbochargers? There is a tag on each, between the top oil inlet fitting and the side coolant port, with a part number XXXXXX-xxxx. Any photos of the exhaust? The 0.6bar sounds very conservative, but a lot depends on the tuning, and how much your 915 clutch can withstand. |
I did not convert the car but it is Garrett M27 AR 48 turbo`s after what i can see
Is that not called the T series turbo? Quote:
M27 -- is that cast on the compressor cover? There should also be an ID tag on the bearing housing.
The only reference to "Garrett M27" I find is a small GT15 turbocharger, OEM for 2.0L Saab Turbo, etc. We've used two for a twin turbo before, but on a smaller displacement engine <3.0L. http://forums.pelicanparts.com/uploa...1315531615.jpg Even on the small engine, these turbos were a little too small, too much turbine back pressure. Went with a pair of bigger turbochargers and didn't lose any response, and gains in performance. |
TurboKraft
I just wrote down what i could see when the car was taken apart when we restored the car The turbos on your picture looks a bit smaller than the ones on my car(it might just be the picture)but the turbos works very well I will have a better look when i have the car on a lift There is no turbo badge on the car and even if i put in bigger turbos it still will not have turbo badges. I might go for a 911 badge but that is all. Never thought about the turbos but now i have to see what the tag says. If i remember right it is a blue tag on the turbos and the tag was hard to read without taking off a turbo but i need to know even if that mean to take one off:) The brakes on the car i Brembo big reds One qustion about the length of the exhaust pipes i have seen some that use long exhaust pipes and some that use short pipes. What is the best on a 911? This is how the set up looks(i need to wipe/sand off the the dirt and surface rust on the exhaust) It is the only picture i took before painting of the car You can see the intercooler under the masking paper. It for sure sound loud when you use the car:) http://i414.photobucket.com/albums/p...osanlegg-1.jpg |
If so, shorter exhaust pipes are best to minimize lag. |
No i have heard about the length after the turbos will affect the cars performance.
After what i understood is that there is some benefits with long pipes and also some other benefits with short pipes |
BEFORE the turbo, you want shorter exhaust pipes (i.e. the primaries on the headers) to maximise exhaust gas velocity, which spools the turbo up quicker. That's the theory anyway SmileWavy |
Longer equal length header will give out smoother exhaust energy to turbocharger. Heat = energy, longer pipe = heat lost before turbocharger, some use thermal barrier coating or header wrap to keep heat in the piping. Some use thicker 3mm stainless steel pipes. Short unequal length header give out fast respond, but cancel some of energy between cylinders. Long equal length header = higher HP number. Short equal length header = faster turbo respond. |
| All times are GMT -8. The time now is 12:52 PM. |
