laughac's Avatar
Send a message via AIM to laughac
Has anyone back-dated a 3.3 distributor before?
While I decide which EFI to try, I would like to backdate my 3.3 distributor to use it without an ECU. I have a '77 car so I don't plan to update the wiring to match the stock '87 engine.
Concerns:
1. The '87 3.3 distributor has reversed the direction of the drive gear that was in my '77 2.7, so I can't use either at this point.
2. I don't have, nor want an ECU.
3. I'm not ready for a crank trigger system until I choose an EFI setup.
Any good suggestions?
All I want to do is make the 3.3 disty accept my simple MSD setup, or find an easy replacement.
Thanks!
2000 Boxster S
2004 330ci convertible
1978 450 SLC
1924 Model T Ford touring
Fleet of Ford Buses, Sedans, SUVs and Limos
Old 09-06-2011, 05:33 PM
Crotchety Old Bastard
RarlyL8's Avatar
No 3.3L 930 engine has an ECU. All 930 distributors use mechanical/vac/boost timing curves.
Old 09-06-2011, 08:06 PM
laughac's Avatar
So my 2.7 wiring harness will work with the 3.3?
I guess I assumed that it wouldn't work because I don't see any points inside.
If so, thanks much!
Now I just need to wire it right.
I wonder where I can look for pics or diagrams for this swapover?
2000 Boxster S
1978 450 SLC
Old 09-06-2011, 08:15 PM
