Tilikum Turbo's Avatar
Advantage(if any) for removing stock wastegate 'muffler'...
I have seen a few pics of motors with what looks like the standard KKK Turbo/factory wastegate system, but seen a few with nothing more than a angled pipe as replacement for the baby-muffler coming off wastegate.
Pro's and con's to this? My thinking is on a cold day, with no buffer between the muffler and the exit of the turbo, exposure to that cold air could quickly warp the blades on the turbo(somewhat like an open exhaust being hit with cool air after shutdown can warp exhaust vavles).
Thanks!
1983 911 3.3L Turbo(YES, I know the turbo badge is on the right...had to be different!)
1996 Toyota Corolla(der 'clapper')
Old 09-11-2011, 01:51 PM
Smart quod bastardus
fredmeister's Avatar
cannot effect the turbo in any way. it reduces back pressure on the wastegate which is a good thing. will effect your emissions slightly and may throw a red flag to your state inspection if you are required to go thru a visual inspection.
will throw flames on boost and sounds awesome.
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 09-11-2011, 02:16 PM
Banned
The primary advantage is that the sounds that come out of the unmuffled pipe are sure to give you instant wood (maybe a viagra substitute?) !!!! Sometimes, just looking at it can have this effect . . .
Old 09-11-2011, 02:53 PM
mark houghton's Avatar
Took mine off many moons ago. All it used to do was to muffle the glorious sounds. No functions other than that. I think Porsche put them on in favor of the soccer-moms, not wanting to make any noise suggestive of a high performance machine. Right up there with all the emissions crap.....
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ.
Old 09-11-2011, 04:02 PM
Turbofrog
smurfbus's Avatar
I put my muffler back and it still sounds bad a**. Straight pipe was a bit too much attention but I will likely try it again next summer just for fun.
If I want attention I can always shut the ignition on an over run untill it gives a HELL of a BANG, but thats not healthy for the turbo as the bang probably explodes in the header.
10/78 930: HX40Super, MS3pro+IDX1050+044+E85, ITB, 12 Denso COPs, TrueSplit-BB/2*38WGs, Weight<1100kg
Old 09-11-2011, 08:37 PM
DSPTurtle's Avatar
+1... when you hit boost and the waste gate opens, you definitely know you are driving a Porsche. I cut my waste gate muffler open to remove the baffles (I posted that process on here somewhere) and it is still too quiet compared to a straight pipe. Unfortunately the quad pipes on the SE exhaust require you to bolt the left side pipes to the waste gate
JB - BreitWerks
www.breitwerks.com
321-806-8664
Engine Rebuild & Restorations
Old 09-11-2011, 10:24 PM
Mine is wide open and it makes it sound like you have a jet engine under the tail when accelerating on boost. Its really cool when driving next to a retaining wall on the road.
Plus you save a few extra ounces of weight off the rear of the car too!
Old 09-12-2011, 10:44 AM
