Until the thub returns, I use the time to work on everything else:
Door cut-outs are to small and don't look that good: http://forums.pelicanparts.com/uploa...1327351241.jpg As I decided to remove stereo I will increase and change layout of the opening. Here is the result of about 20 versions I created and compared: http://forums.pelicanparts.com/uploa...1327351369.jpg ...And I received my new steering wheel today:) http://forums.pelicanparts.com/uploa...1327351508.jpg |
Incredible Roland! Keep it going for sure. BTW...nice rabbit! We have a dwarf Netherlands.
Today I received new rear light housings. I decided to buy aftermarket plastic ones, lighter and cheaper then stock. My old ones had almost no more shiny chrome inside. I spray-painted them a few years ago with chrome effect, but it did not last long and was not really shiny either...
http://forums.pelicanparts.com/uploa...1327530531.jpg http://forums.pelicanparts.com/uploa...1327530857.jpg |
Bought them here:
911 1969-89 Rear Light Unit Right - Detailed item view - Type 911 Just saw the price increased. I paid 125 GBP each, now they are 135 GBP PS: Weight is on the kitchenscale about 300g each without lens like on pic |
First door finished:
http://forums.pelicanparts.com/uploa...1327790185.jpg And another drilled part: http://forums.pelicanparts.com/uploa...1327790272.jpg |
Fanatical! I like it!
Made some molding tools to cut the foam panel with my homemade cutter
http://forums.pelicanparts.com/uploa...1328737433.jpg It's a simple construction with a hot wire (made for this application) using a power supply (not on pic). Costs about 100 USD all in all http://forums.pelicanparts.com/uploa...1328737673.jpg And that the result, a nice moulding that is pretty precise to use for laminating http://forums.pelicanparts.com/uploa...1328737870.jpg |
Dr. Drill is back
once more...
Man, you are amazing with your patience for drilling.
I think you need a therapist - like now! :p
BTW: that steering wheel looks like a Mod 7 but in leather rather than swede/alcantra . . . |
Correct, Mod07 in leather |
Door panels laminated and removed from moulding. Unfortunatly I had issue with parting agent, was too old...
http://forums.pelicanparts.com/uploa...1330464724.jpg http://forums.pelicanparts.com/uploa...1330464812.jpg But not a big thing. Only a bit more working on the surface before painting |
Body has left for a while
Today it was picked up for blasting, body work and painting. Will post some pics of progress from time to time
http://forums.pelicanparts.com/uploa...1331331142.jpg http://forums.pelicanparts.com/uploa...1331331214.jpg http://forums.pelicanparts.com/uploa...1331331287.jpg |
http://forums.pelicanparts.com/uploa...1324682757.jpg[/QUOTE]
Great work! But what kind of cat is that with the big ears............just kidding..cute bunny |
| All times are GMT -8. The time now is 12:44 PM. |
