935TURBO's Avatar
Wich coil-on-plug for my 930 twin plug...?
Hi guys,
wich COP would be ok for the best fitting on my futur 930/66 twin plug....?......and wich ignition unit....?
Thanks.
Serge, Gentleman Driver
https://www.facebook.com/photo.php?fbid=10207116408000968&set=gm.1723624077 855805&type=3&theater
Old 11-28-2011, 09:50 AM
Ken911's Avatar
I have been told vw turbo 1.8l 2004. works and also the toyota one for the new camery. I plan on using the toyota ones for my EFI swap.
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's.
2019 Silverado 6.2L
Old 11-28-2011, 02:25 PM
I've heard of people using GM coil packs quite successfully too.
Old 11-28-2011, 02:32 PM
Banned
Honda CBR coils,M&W ignition and call it a day.
TurboKraft's Avatar
Which valve covers are you using?
Standard 911/930 camshaft housings?
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 11-28-2011, 03:10 PM
Ken911's Avatar
i am using the stock ones on top and 964 ones on the bottom.
2019 Silverado 6.2L
Old 11-28-2011, 03:17 PM
935TURBO's Avatar
I wille use the stock ones I got machined....
Old 11-28-2011, 05:55 PM
Certified User
billjam's Avatar
Serge,
While this is on my 3.6 NA engine and not on my Turbo, the same COPs could be used for both. I am using Toyota coil packs 90919-02246 (from several mid 2000's V6 engines). Cheap on eBay.
The standard Toyota seal under the head of the COP is too thick and too big in diameter to suit the 964 rocker covers so I am using a smaller rubber seal to close the gap.
I made up a bracket that is fixed to the lower rocker covers to secure the lower coils. The top coils sit in place securely without fixing bolts.
These coils will be fired by a 5V ignition signal from Megasquirt MS3X.
I have just received parts back from powder-coating so I fitted them together loosely for pics. "Dirty" pics below are of engine pre-assembly before plating and powder-coating.
Bill
1988 Carrera - 3.6 engine with ITBs, COPs, MS3X
2024 Macan S
Day job ... www.jesfab.com.au
Memories: '68 912, '72 911T, '80 911SC, '84 911, '85 930, '86 930, '87 911, '21 Macan S
Old 11-29-2011, 02:21 AM
935TURBO's Avatar
Thanks Bill for that answer....very nice project....have ypu a specific thread....?
Old 11-29-2011, 02:47 AM
Certified User
billjam's Avatar
No specific thread Serge, just a few threads on different parts of the engine build.
It has been a long-term intermittent project, but the engine is almost ready for assembly.
I may pull it all together into one thread eventually in the Tech or Engine forum.
Bill
2024 Macan S
Old 11-29-2011, 03:18 AM
935TURBO's Avatar
And for those who aren't running EFI, wich control unit are you using....?
Old 11-29-2011, 04:04 AM
TurboKraft's Avatar
Denso coil on 930 upper and 964 lower valve covers.
An additional rubber seal is needed to fully seal to the upper valve covers.
Couple that with an M&W CDI and you have an extremely powerful ignition system.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
Old 11-29-2011, 08:35 AM
Ken911's Avatar
Does it have a built in igniter? what denso part number?
2019 Silverado 6.2L
Old 11-29-2011, 12:27 PM
Banned
Same as Honda CBR coils.(Denso).,you don't need igniter with these combo(Denso & M&W).
Old 11-29-2011, 01:22 PM
I used some AEM COP's and a couple of AEM 8 Channel CDI units. So far they have performed OK and have been trouble free - although no "real" hours on the engine yet. I used 964 valve covers and placed an O-ring on the COP that fits snugly into the opening on the valve covers. They take a fair amount of effort to get off - so I haven't needed any other retainers yet.
Richard.
RSR Replica - http://forums.pelicanparts.com/porsche-911-technical-forum/472762-rsr-update.html
930 Cab - ex-IA car, 3.4L, 1.2 bar, G50
996 Turbo - X50.
Old 11-29-2011, 05:58 PM
Ken911's Avatar
Thats about the nicest looking harness i have seen yet. Did you build it?
2019 Silverado 6.2L
Old 11-30-2011, 01:09 PM
That is the nicest COP install I've seen. Nice job.
Old 11-30-2011, 02:21 PM
935TURBO's Avatar
Yes, very nice job.....very well done....I'll take a look for the CDI units...
Old 11-30-2011, 02:40 PM
Thanks guys. Yes I made the loom myself.
The AEM Twinfire CDI units come prewired with a fair amount of wire and good quality Deutsch plugs. The COP's come with unterminated plugs.
The Loom and fittings I brought from Waytek Wire however I don't think they carry it anymore on their on line catalog. The loom and fittings are made in Germany by a company called Schlemmer. They clip together which makes it easy to layout the loom first and then insert the wires to suit.
Richard.
996 Turbo - X50.
Old 11-30-2011, 03:10 PM
spence88mph's Avatar
Richard.
A lot more pics and info on this build needed asap! Very nice work.
'89 911 M491+Turbo
'90 964 C2
'89 944 Turbo
'88 928S4
Old 11-30-2011, 03:11 PM
