Poll: Should I check the tranny too as I had a few noisy shifts due the issue
Poll Options
proffighter's Avatar
Strange clutch issue
As I already talked about a clutch problem earlier (see rust combat thread) I now parted the tranny off the engine to see, what happend here.
Reason for this was shifting was getting harder from each time to time. First I thought, syncronisation failed, but then clutch started to seperat only bad and even worse each time and within a few kilometers, it did not separated at all. I readjusted (lot of play) the cable, but it only helped a few times, then It was the same. My guess was a failure of the release fork, but fork looks fine.
Here some pics:
Roland
930 Turbo '81 Too many modifications to list
Old 12-11-2011, 03:56 AM
Does someone had similar problems? It all looks fine for me...
What I can see is, that throw-out bearing turned in the spring...
Roland
Old 12-11-2011, 03:57 AM
pete3799's Avatar
Check the roll pin on the pedal cluster that goes through the clutch pedal. sometimes they break and allow the pedal to move without pulling the cable.
Next suspect would be the cable itself is failing.
Pete
79 911SC RoW
Old 12-11-2011, 04:59 AM
beancounter
jwasbury's Avatar
What is the condition of the throw out bearing? Does it spin freely? The throwout bearing guide tube has been "polished" as if by friction. Perhaps this is a another sign of a problem with the throwout bearing? That guide tube needs lube in order for the throwout bearing to slide forward and back freely during clutch actuation. Without proper lubrication, the clutch pedal can become very stiff, and the clutch mechanism binds during engagement and release.
Jacob
Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690
Past: 2009 997 Turbo Cab / 1979 930
Old 12-11-2011, 05:26 AM
Roby466's Avatar
Could your clutch cable have enough broken threads that it stretches causing the adjustment to work only for a few times?
1985 Black 930, K27 7006, Garretson Intercooler, Adj boost, TB: 23 - 31mm, bielstein sport shocks, ER polybronze bushings front and rear, ER monoball joints front and rear with offset camber plates, 935 X triangulated strut brace, raised spindles, racing bump steer kit
1981 Black 911sc (sold)
Old 12-11-2011, 08:51 AM
Thanks for that quick replies
@pete3799
That's a thing I've heard before, but forgot completly to check... Will do that next time in the garage
@jwasbury
Bearing looks fine, runs smooth and no play. But it was not lubed very much, so that's a good idea for the reassembly. As there is only very little play and the bearing is not centered except by the spring, there is the possibility to touch the tube
@Roby466
I don't think so, because the cable is only 10'000 running, but will check as well
Roland
Old 12-11-2011, 09:13 AM
Smart quod bastardus
fredmeister's Avatar
Your cable may have stretched but not totally failed. if you had lots of slack thats the problem. Once you adjust it back to spec it should have worked fine, unless it continued to stretch every time you activated the clutch. Sometimes several strands will break in the cable so that it still works slightly but is stretched so its out of adjustment badly.
Your guide tube for the throw out bearing looks worn too which indicated an issue with missing lube for this surface and possible issues with the throwout bearing. Since its apart already I would replace the TO bearing before putting it back together.
Did you check the tranny shaft support bearing inside the crankshaft end to see if its still lubed and working? Sometimes this needle bearing fails and prevents the tranny shaft from spinning free of the crank which feels like the clutch is not disengaging making shifting difficult.
Good luck.
Fred
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 12-11-2011, 09:25 AM
Fred
I will check cable too. The bearing in the crankshaft is a selfmade solution, as my stock clutch had the needle bearing built in, but not the fidanza I use. Further there where no threads in the crankshaft. So I made an adapter and fitted a bearing similar to the newer versions (sealed ball bearing)
I am going now to check and will post results in about 3 hours.
Roland
Old 12-11-2011, 09:34 AM
And the winner is...
...pete3799 Congratulations
Roland
Old 12-11-2011, 11:26 AM
As I found the problem, I want to ask if I should check the tranny itself too. It was running now 20'000km since rebuilt (syncronisation was replaced)
Thanks for voting
Roland
Old 12-13-2011, 12:15 AM
Question
Bump
No votes at all Come on guys...
Roland
Old 12-27-2011, 05:38 PM
beancounter
jwasbury's Avatar
I vote for "if it ain't broke, don't fix it"
Old 12-28-2011, 07:41 AM
pete3799's Avatar
+1
If there is no grinding between gears i'd leave it alone.
Pete
79 911SC RoW
Old 12-28-2011, 08:09 AM
Finally Thanks guys. It is always a good help when other share the same opinion
Roland
Old 12-29-2011, 04:31 AM
