2.7 turbo?
Has anyone here done a 2.7 turbo conversion before?
I assume it'd be the same as a 911SC 3.0 conversion? Same compression ratio of 8.5:1? What would one do to strengthen the motor? Stronger fasteners? Twin plug? Lower compression forged JE's? EFI conversion? |
Yes.
Search for DPHans. That is the most radical as I remember. There are others as well. |
Yes, DPHans has made a nice twin turbo 2.7l.
Think he used a 928 CIS head to have 2 extra injectors for fuel enrichment on top.
Trond R. 1979 930: Garret GT35r turbo, EFI, carerra intake, Link EMS, custom GT2 cams, 98mm JE P/C, 964 crank (stroker), custom valves & ported (XtremeCylinderHeads) etc..etc.. 1972 914-6 GT replica project 1986 944 Turbo |
DPHANS
Hi all..
Yes I still have my DP 935. But I have over rewed the engine. a massive over rew. So the car is standing in my garage until I have time to strip it down. To build a engine on the 2,7 base is easy. 1. Lower compression. 2. Steel bolts / cylinder heads 3. a lot of fuel. No way to use original fuelhead. example, 928S/ MB 560 God luck. DPHANS Youtube = DP935 MANTORP
Only Dp 935 cars for me : Dp 935 2.8LTwin Turbo and a Dp 935 Cab 3.0L Twin turbo. Dp 935 3.0L coupe Visit Youtube= DP935 MANTORP |
Wow, how much boost is he running on that 2.7? 1.4 - 2.0 bar?
![]() Awesome car! Huge respect for people who think outside the box and try something different!
DPHANS
Hi.
I have been running this car for 4 seasons now. Every track day I was happy that the engine will stay alive. Ok this time I had Full speed on 4th gear. just to trow in the 5th gear,,, wow I got the third gear. black stripes in the mirror. My intension was to pass a F 430..I ¨-was beside him when this was happened. Sometimes I go for 1,4 bar in boost /This with 50 % Ethanol But I have better lap times with 0,9 bar,, DPHANS
Hans, have you had the car on the dyno?
I'd be interested to know how much power your motor is putting out! ![]() How much HP can each turbo flow? Do you know the A/R of the Turbo's hot housing? I've always wanted to try out two T3 60 Trim turbo's (32-35lb/min compressors) with 0.48 A/R turbine housings. I know top end power will be limited by the smaller turbine housings, but the bost response would be amazing! Even if it was limited to 400HP, it'd be a very nice setup
DPHANS
Sorry. I don't like the dynos, I just drive and If it feels Ok for me, Iam happy.
My small turbos TD04/12 can give max 480hp. I think I have 375-400hp with 0,9-1.0 boost. My dyno is on a race track. on a long straightaway I have no problem to follow GT3s. ![]() DPHANS
Awesome looking setup! Aren't the turbo inlets a bit TOO close to the exhaust? How hot does that intake pipe get ![]() Quote:
![]() Great shot of the flame thrower too
DPHANS
Reply: One word. Asbestos.... DPHANS
DPHANS
I think you shoud start a tread about you and your cars.There is alot of knowledge you sit on that i think most oldshool gus would appriciate and maybe (propably) all others also ![]() By the way it`s time for speedweekend Orsa again. I´m signed up but I´m not shore what car I will compete whit, almost shore not the 930 turbo since last year. Kandidates: Lada Niva turbo Russian terraincar. 911-75 2.7 bergrennen 915gearbox TBIs from bike MS or Haltech portjob. Toyota Corolla-72 BMW M10 turbocharged 500+hk Volvo axle. Have all the parts but none is finished jet
DPHANS
Have problem to find Rims for my stud? tires..I have my plans. so let see.. DPHANS
Subscribed
Turbonut
DPHANS, you use mag case right?
Did you prepped it specifically for turbocharging like shuffle pinning or something? I'm sort of interested in this subject as I'm building a 2.5liter short stroke turbo engine myself (66mm crank, 90mm RS P&C's, S cams, CNC ported and twin-plugged heads 40/37mm, custom ITB dual-plenum intakes, VEMS EFI etc). Just in the middle of taking a decision regarding case. Obvious move would be early aluminium case but these are very rare and very expensive. Seeing a T holding up so well makes using mag case tempting as my car will see track only occasionally (I have a race-car for that).
'83 924 (2.6 16v Turbo, 530hp),'67 911 hot-rod /2.4S, '78 924 Carrera GT project (2.0 turbo 340 hp), '84 928 S 4.7 Euro (VEMS PnP, 332 HP), '90 944 S2 Cabriolet http://www.facebook.com/vemsporsche |
