Reinstalling ELECTROMOTIVE HPV-1 some questions
I am going to try my best to explain things.
I'm reinstalling the Electromotive HPV-1 ignition that came with my car. The wires were a mess and I did not pay attention when I removed the engine.
My car is a standard 1989 carrera that has a 88 930 engine installed .
The engine is running dual plug set up with dual electromotive HPV-1's .
I have looked over the install instructions on page 10 but still have some questions
http://distributorless.com/pdf_files/hpv1.pdf
The system is wired to the positive terminal on the starter, this runs to 2 bosch relays
(bosch relay # 0332 019 150 - 30Amp relay)
My questions are the following-
what wire could I use for the ignition switch signal for the relay's
The Warm up regulator and air flow meter (is wired into the ignition relay) . It seems they have power as soon as the ignition was turned on . Is that correct? Should this be rewired?
The car originally did not have the 2nd rear fuel pump. This was installed but its also wired into the ignition replays ( I dont remember how)
any thoughts on how to correctly install this
Old 06-04-2012, 08:11 AM
