Idle is high
Stock 86 w CIS,, starts fine, runs great. Problem is the idle is really high,, Can't seem to adjust it out..
If I push down slightly on the throttle plate it goes right down as long as I hold it. Suggestions ? I tried setting the mixture richer but it doesn't seem to help.
"Todd" 98 Tahoe ,2007 Saturn Vue 86 930 black and stock, 80 930 blue tracdog 91 Spec Miata (yeah I race a chick car) "life"ll kill ya" Warren Zevon |
Banned
The most likely cause is a air leak after the throttle body. Do you still have the vacuum limiting valve (aka - deceleration valve) in place? When I experienced a high idle that would not adjust away it turned out to be a faulty decel valve which was letting air by at all times . . .
Thanks Ronnie, I'll check it out.. Makes sense since I just put the engine back in
Forced Induction Junkie
Dave '85 930 Factory Special Wishes Flachbau Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P |
Banned
I bet Dave has it covered - I didn't pay enough attention to the "pressure on the throttle plate" part in the original post! I agree that this would indicate that the throttle plate is not closing enough.
Smart quod bastardus
It could be throttle linkage related. I had to replace the throttle belcrank bushes on my engine mounted belcrank bracket since they were completely worn and distorted. its hard to see with the engine back in the car, but this could be the source of your trouble.
Also it could be the auxilairy air valve is not closing all the way. if your stock CIS is all there, check out whether this valve is closing when its warm.
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max ---"When you're racing it's life! Anything else either before or after, is just waiting" |
Quick update,, I don't think it's the linkage because the TB IS closing all the way,, I need to push it open to get the throttle to drop....
Air pump/ stuff has been removed from the CIS.. I'm going to chase down the vacuum leak idea in the next day or so.
Since nobody has asked yet, then I will. How's your AAR working? Not closing, perhaps? Is power getting to it, to heat things up and close it when warm?
Simple in-car test would be to pinch the hose at the AAR completely closed to stop any air from entering. RPM's would instantly drop IF the AAR was stuck open.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ. |
I've gone native
Mine does the opposite, after about an hr of driving the idle drops to a point where the car will stall.
Same issue? TIA, sorry to hijack, but a related issue
'07 997.1tt Blk/blk 600hp, bad to the bone |
But before messing with the mix, first adjust the idle speed via the screw that's a b- -ch to get to, to get your idle up and stable.
Turbofrog
A loong screw driver does the job for the throttle screw.
************************************************** ******************************* 10/78 930: HX40Super, MS3pro+IDX1050+044+E85, ITB, 12 Denso COPs, TrueSplit-BB/2*38WGs, Weight<1100kg |
I've gone native
thanx will try, but when it's not that hot or less than an hr of driving doesn't do it at all and idles normally
Tt next time it happens take a look and see if your fuel pump fuse (6th one in from windshield) or 2 fuel pump relays (closest to windshield) are hot.
'87, Modified WUR, Billet valve, 965 downpipe, Kokeln intercooler, GHL headers, Garrett T04B K27 hybrid, Tial w/.8 bar, WEGO IV, RarlyL8 dual out, LSD |
I called it the auxialiary air valve.....some say tomato some say potato.....you know what I mean.
AAV vs. AAR. My thoughts: A valve is either on or off, whereas a regulator is infinite in it's position. I have no idea which is the correct term, but we're all talking the same thing so who cares?
As a side note, mine stopped closing down as it warmed up and I wound up with an extremely high idle (2000rpm) a while back so rather than pay $1200 for a new unit, I removed it. The car is a little harder to start in cold weather now and is cold blooded for 2-3 minutes until it warms up, but works fine without it otherwise. Later, Fred
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max ---"When you're racing it's life! Anything else either before or after, is just waiting" Last edited by fredmeister; 05-03-2012 at 09:55 AM.. |
And yeah, I thought I detected a NY accent. Just so happens my best friend is from Brooklyn.
I've gone native
I'm gonna do some diagnostics that mark suggested, but sounds like one of the fuel pumps is out. c
Tt I had the same problem as you, after driving for a bit the car would not idle, had to keep my foot on the gas at all times, I actually learned how to heel toe because of this problem. My fuse was hot and one relay. I rewired my fuel pump fuse like this 930 Fuel Pump Fuse Overload - The Solution. Now that I have two fuses and the two red relays I could pinpoint what pump was not getting power or was faulty. Maybe this weekend you come by Captree or maybe Milleridge In and I will show you exactly how I delt with this problem. It was not AAR or AFR adjustment related but instead power getting to both fuel pumps properly. JMHO
I've gone native
Al, that sounds good, give me a call on my cell
c
