-   -   wondering on building a TT without the intercooler (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/682206-wondering-building-tt-without-intercooler.html)
copbait73 06-09-2012 05:01 PM
If you side mount the twins you will need a '72 oil tank and system.
If you rear mount the twins, turbines opposed, your valance will only give you room for straight out pipes - really loud.
Mount the twins to the rear compressors opposed and you can work in some muffling.
The "G" body, '74 up, rear bumper added critical space for all turbo stuff you want under there.
Reaper930 06-09-2012 05:09 PM
I side mounted my TT 3.8 with a stock 930 setup FWIW. Before I saw the light and went rear mount, and yes its L O U D.
If you side mount the twins you will need a '72 oil tank and system.<br>
If you rear mount the twins, turbines opposed, your valance will only give you room for straight out pipes - really loud. <br>
Mount the twins to the rear compressors opposed and you can work in some muffling.<br>
RarlyL8 06-09-2012 07:44 PM
PW put together one of the most impressive no-tail presentations I've ever seen.
Yes it does have intercoolers in a place worth consideration.
http://forums.pelicanparts.com/uploa...1339296103.jpg
James Brown 06-09-2012 08:19 PM
thats a monster Brian, are the pipe lengths too long to have a front mounted intercooler? Oil tank relocation should not be a problem. maybe tone it down a bit so it does not look like a indy car!!
good stuff, keep it coming...
RarlyL8 06-09-2012 09:22 PM
P. Wong put that one together as an engineering project of sorts. I think he had a thread on it at the time (a few years ago). Crazy looking and must have sounded just as nuts!
TurboKraft 06-09-2012 10:07 PM
We find side mounting twin turbo easier, and makes for the shortest plumbing. Like the 993T.
You can keep re-use the factory rear mounted oil tank with easy, low cost mods. Then you have the whole bumper area for your muffler system.
Email or PM for pics.
Converting to a 964 or 993 oil tank isn't that difficult either, but not a requirement.
RarlyL8 06-10-2012 04:52 AM
... but rear mount retains the cool factor. http://forums.pelicanparts.com/suppo...ool_shades.gif
Also makes adjusting the valves a lot less time consuming. For me if you can't see the twins they aren't worth doing. To much cost/complexity for little to no gain.
willtel 06-10-2012 06:54 AM
This one fits under a 3.0 Turbo Carrera tail.
http://i57.photobucket.com/albums/g2.../ICfitted2.jpg
http://i57.photobucket.com/albums/g2...t/ICfitted.jpg
Reaper930 06-10-2012 01:46 PM
Or you can just go the backseat route :) works well enough for a K3...
http://forums.pelicanparts.com/uploa...1339360696.jpg
http://forums.pelicanparts.com/uploa...1339360779.jpg
http://forums.pelicanparts.com/uploa...1339361154.jpg
TurboKraft 06-12-2012 09:53 PM
Originally Posted by willtel (Post 6796353)
That intercooler setup looks familiar... Nicely done, sir! :-)
Bryan's 1974 Turbo RS 3.0
1976 Porsche 911 Turbo Carrera | Bob
http://forums.pelicanparts.com/uploa...1339563172.jpg
