Tinkering Pays!!
mooney265's Avatar
Question Removing Turbo - - Can't scratch my 4th Nut?
I'm attempting to remove the turbo so that I can have it sent off and ceramic coated [hot side]. K27 HF that i had installed at a shop 4k miles ago...
Am having trouble getting to the final 14mm nut on top in the Front/Driver location. I've got B&B header system and have removed 3/4 of the allen head bolts [come up through the bottom].
Any advice would be greatly appreciated!! SEE PIC:
Shannon
LIVN80S - - Red '79 Porsche 930 Steel Slant Nose Conversion [in 1987] w. 46k miles 3.3L; 964 Cams; K27HF @ 1.0 BAR, with Garrettson Intercooler; Rarly Zork; CIS Flowtech Fuel Head & BL-WUR.
Old 08-04-2012, 08:22 AM
Brando
quattrorunner's Avatar
Hack saw?
Old 08-04-2012, 08:48 AM
I've gone native
Tt surgeon's Avatar
The header flange or the turbo flange?
I used an extension with a swivel joint and a six point socket. A shorty ratchet hand wrench is also helpful.
Old 08-04-2012, 09:13 AM
Tinkering Pays!!
mooney265's Avatar
I got it by removing the other 3 and rotating the turbo about 15-degree ccw. It's off now!
Sent from my MB855 using Tapatalk 2
Old 08-04-2012, 09:36 AM
Why the ceramic coating? I think they are titanium wheels. Does the coating add any weight? Is there any chance of misbalance?
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 08-04-2012, 01:21 PM
Tinkering Pays!!
mooney265's Avatar
I believe i'm only coating the hot-side housing [inside and out]...
Old 08-04-2012, 02:32 PM
Tinkering Pays!!
mooney265's Avatar
I scratched it!
Old 08-04-2012, 02:54 PM
A short wrench and lots of patience, 1/8 of a turn at a time - at the most - forget the coating.
Old 08-05-2012, 10:40 AM
Tinkering Pays!!
mooney265's Avatar
You saying: Don't ceramic coat the hot side [inside and out]? Just curious...
Old 08-05-2012, 11:30 AM
mark houghton's Avatar
I don't have any trouble scratching my two God-given nuts but if I had an extra set the women would be lined up at my door (or so I wish).
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ.
Old 08-05-2012, 02:01 PM
IMO, I don't see the benefit of the coating, or a blanket on a turbo; I rather let it breath naturally.
Old 08-06-2012, 05:10 AM
Tinkering Pays!!
mooney265's Avatar
The benefit to me/the car would be getting the heat out from under the bumper. Mine gets hot and has melted a reflector or two...
Old 08-06-2012, 05:53 AM
I've heard that before, definitely the exception not the rule, something was changed under there to generate/trap that heat; FYI, my 78 still has the OEM bumper/reflector AND shield... I added a pieces of fire blanket between the shield and the valance JIC, they get hot but never so hot to melt anything even here in Alabama during track events... I've seen air fins installed from under the turbo directing air up to vent the area; I believe Turbocraft offers one.
Old 08-06-2012, 07:00 AM
Tinkering Pays!!
mooney265's Avatar
when the car is moving, i don't have a problem. it's the stop-n-go stuff down here in new orleans that let's the heat accumulate...
Old 08-06-2012, 07:39 AM
The high tech aluminized heat barrier cloth works wonders. I have used it on 3 of my cars now. It is expensive but easy to cut/fit and makes a huge difference. The more HP you develop, the more you need something like this.
JR
Old 08-22-2012, 02:38 PM
I got some "crow foot" open end wrench ends that fit onto a 3/8 ratchet or extension. This allowed me to get to all the nuts much more easily, and using the ratchet I could click away a notch or two at a time until I got them free.
Emery
1988 930 coupe - Silver Metallic
TurboKraft 3.3L 8:1 CR, SuperSC Cams, GT35R, B&B Headers, TK intercooler, Tial WG, ARP, tecGT based phased sequential EFI & ignition, Wevo shifter/coupler, ...
Old 08-22-2012, 05:14 PM
I've gone native
Tt surgeon's Avatar
Shorty hand wratchet works well too.
'07 997.1tt
Blk/blk 600hp, bad to the bone
Old 08-22-2012, 09:24 PM
