Smart quod bastardus
fredmeister's Avatar
how to make stock wastegate adjustable
ANyone know how to make the stock wastegate adjustable for boost pressure.
I know that the central air tube from the wastegate housing goes to atmosphere. There should be a way of installing a pressure relief valve of some sort to this line to control the pressure to something below atmospheric.
This would have the effect of creating a smaller differential pressure inside the wastegate and thus alowing more engine boost before it opens.
I know the theary but need to know the hardware to make this work.
Anyone have tried this that could show the install to do this? I was hoping to do this with mechanical valves or something inexpensive. Do not want to start springing big bucks for electronic boost controllers and such.
Fred
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 11-09-2007, 01:08 PM
sudo apt-get purge 930
equality72521's Avatar
What about a manual boost controller then? They are much less expensive than an EBC.
--clutch-monkey
Old 11-09-2007, 01:41 PM
930gt-40r's Avatar
Fred its easy, Just put a knot in the line going to the bottom port, you didnt know?
Just kidding- I used to have a GFB (Go fast bits) mechanical boost controler and it worked great. I used a Tial 46 with a 12 lb spring. This controler used only the bottom port. I also have a Turbonetics manual in my garage that utalizes both the top and bottom ports.
But the first one I mentioned was a lot simpler and worked great.
Kris @ Tech9
86' 930/GT-40R Sold
94' Rustang GT daily (long gone)
2008 C6/Z51 Corvette
Old 11-09-2007, 08:56 PM
9dreizig's Avatar
Send a message via AIM to 9dreizig
My roller had one of those when I bought it.. Don't they call them "dial a grenades" for a reason ?
"Todd"
98 Tahoe ,2007 Saturn Vue
86 930 black and stock, 80 930 blue tracdog
91 Spec Miata (yeah I race a chick car)
"life"ll kill ya" Warren Zevon
Old 11-09-2007, 09:15 PM
dewolf's Avatar
Get a manual boost controller and leave the over boost switch connected. Mine has faultless for over a year.
Old 11-09-2007, 11:35 PM
beepbeep's Avatar
It's easiest to leave the vent as it is and just reduce the pressure going to the bottom of the wastegate bell by ways of fitting controllable "vent" valve on a hose going to it.
It can be easy as simple plastic T-orifice or as complicated as electronically PWD-operated electro-magnetic valve.
Just remember one thing: You cannot reduce the boost below basic spring setting, you can only raise it. That's why I'm a strong opponent to practice of fitting harder wastegate springs.
Thank you for your time,
Old 11-10-2007, 02:06 AM
930gt-40r's Avatar
If your talking about the turbonetics unit where you have to pull the knob up and turn to adjust; thats the exact same thing I was thinking. It felt like some kind of weapon of war that you set before tossing over enemy lines.
Kris @ Tech9
86' 930/GT-40R Sold
Old 11-10-2007, 06:13 AM
A fellow Pelacanite
NathanUK's Avatar
You guys mean "Dial a Death"
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 11-10-2007, 03:43 PM
930gt-40r's Avatar
or "Dial a Boom"
Kris @ Tech9
86' 930/GT-40R Sold
Old 11-10-2007, 03:46 PM
9dreizig's Avatar
Oh by the way, I have one from the PO.. I'll be happy to sell it to you, make me an offer..
T
"Todd"
Old 11-10-2007, 04:24 PM
Interested.....this is exactly what I had in mind but did not know where to find one and who made them.
Can you send photos of what this looks like, both installed and not if you have them?
Does it mount in the engine compartment then and you just set it and leave it alone? The factory 935 used a dial that was adjustable in the cockpit.....but this may be too tempting.
thanks,
Fred
Old 11-11-2007, 05:29 AM
9dreizig's Avatar
It was mounted next to the emergency brake. I'll try to take a pic today and post it.
T
"Todd"
Old 11-11-2007, 07:41 AM
A fellow Pelacanite
NathanUK's Avatar
I'm sure RUF did this as well and they were pressure regulators. They tee'd into the control line, the regulator went from the tee & then from the reg to the vent on the WG.
Old 11-11-2007, 10:43 AM
9dreizig's Avatar
Here's a couple of pics,, Make me an offer , or guys let me know what it's worth I have no idea..
"Todd"
Old 11-11-2007, 10:59 AM
thanks,
Fred
A search for "manual boost controller" on Ebay or Google will get 100's of hits for various types that mount in the engine bay, most of which are about $50-80 bucks, tops. Although there's cheaper too.
They're typically just a piece of billet or bar stock with a couple of pipe fittings, the total mechanism in the simpler types consisting of a ball bearing, a spring, an adjusting knob to tighten the spring and maybe a locking nut...
No way I'd put one in the cockpit myself, with a CIS car.
'77 S with '78 930 power and a few other things.
Old 11-11-2007, 11:24 AM
Thanks guys for the info.......how many of you have done this mod?
Any issues with it going out of adjustment......do not wanna hear about the blown engines from deliberatley dialing in 1.2bar boost.
Old 11-12-2007, 07:53 AM
9dreizig's Avatar
Actually, that little red ring that you see under the adjustment ring goes down and locks the adjustment ring in place. You have to pull it up to make any adjustments, I can't imagine that it would ever come out of adjustment once it's been set, it's pretty rock solid.
"Todd"
Old 11-12-2007, 08:18 AM
Crotchety Old Bastard
RarlyL8's Avatar
I'm getting ready to experiment with a boost signal controller like the one pictured above.
What I plan to do is put an adjustable unit in the cockpit and a non-adjustable unit in the engine bay. The non-adjustable unit will be plumbed in parallel with the adjustable unit and will be locked down at a pre-tested 1.0bar. That way the adjustable unit can never exceed 1.0bar.
The factory cutoff switch adds a double redundance of protection.
Old 11-12-2007, 08:23 AM
78P930's Avatar
Can someone post a picture of the ones that Porsche supplied?
Pat
10 Ford Raptor
86 930
Old 11-12-2007, 05:06 PM
RarlyL8's Avatar
Old 11-12-2007, 05:54 PM
