Smart quod bastardus
MSD 6AL2 versus BTM ignition
I have basic question on what is the biggest advantage to the 6AL2 programmable ignition unit from MSD over the MSD BTM unit that has a boost retard function?
THe BTM from what I understand retards boost in adjustable increments and is set without a lap top. This would allow me to run the standard ignition distributor with the vacuum retard function intact and the mechanical advance intact. At the same time I could dial out adjustable boost retard via the BTM box. Is there any more advantage to upgrading to the 6AL2 as the above seems to cover all my needs unless I am missing something. Looking for some input from forum members before pulling the trigger on this. thanks, Fred
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max ---"When you're racing it's life! Anything else either before or after, is just waiting" |
Mr. Fred:
The new 6al2 allows you to program a timing curve for both ignition timing and boost retard. You can also set both programs to 0 and it acts like a stock 6al. And you can set either at 0 and program the other. Good performance and response to be gained by programming curves tailored to your engine specs. Programs with your lap top. You can program and store multiple curves and switch between them for street and track. Cole
Cole - 80 930 "The Old Sled" Mods: TurboKraft Custom IC, 934 Headers, GSX 61, Zork, Port Work, SC Cams, Air Mod Fuel Dist Relocated, Water Meth Injection, BL WUR, MSD 6530, Greddy EBC, Synapse Bov, Short 2nd & 3rd with 8:37 R&P, Wevo Shifter, Coupling, and Mounts, MTX-L SSI-4, Big Brakes, Rebel Coilovers, Bilstein Sports. |
Someday I'll convert to the 6AL2, but for me I went with the BTM initially because my car came with the old MSD6AL and it was an easy thing to add the BTM and not have to mess with anything else other than indexing my distributor (which included grinding the adjustment slot a bit) to get 12 degrees advance at idle. Lots of excuses....like being a poor lazy man, and didn't have a laptop at the time.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ. |
But I had a few questions on hooking the 6AL2 unit to receive the boost signal. The BTM uses a hose connection but the 6AL2 requires an electrical MAP signal. I dont have a MAP sensor in my car but do have the Innovate AUX box which has in internal MAP sensor. I dont know what type of signal output I can get with this. QUESTION: Do you know if the Innovate AUX box can send a signal to the 6AL2 control box to get the boost signal it needs or do I need to buy and install an additional MAP sensor? QUESTION: Do I need a tach adaptor from MSD for the VDO tach or can I tap into the MSD wire directly? They dont address the Porsche specific ignition system on the MSD website......bastards, ha,ha. I would like to leave the distributor untouched so that it uses the mechanical advance as is. QUESTION: Are you saying that I can program the vacuum advance and boost retard functions into the 6AL2 independently of the mechanical advance on the distributor so that I can virtually eliminate the pot on the side of my dizzy? Basically superimposing the 6AL2 programming timing over the mechanical advance timing in the dizzy so that they both add together to alter final timing at the plug wires? And finally, QUESTION: How do you wire the green coax signal wire from the dizzy to the MSD box which has a standard 2 wire type connector? Is there some special adaptor you found that splices into the coax and converts to 2 wire output? Thanks for the excellent advice so far..... Fred
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max ---"When you're racing it's life! Anything else either before or after, is just waiting" Last edited by fredmeister; 12-08-2011 at 06:57 AM.. |
Mr. Fred:
I'll try to take these in order: MAP: You will need a 3 Bar GM style MAP sensor ( Most common MAP there is) I have 4 in my car easy to find on E Bay. You can not parallel MAP signals you need seperate maps. MAPs use a 5VDC signal. With the MSD it will have wiring to connect to the MAP you just provide the MAP sensor and feed a boost line to it. 3 Bar Map Sensors: GM Style 3 Bar Pressure Sensors Manufacturer Part Numbers GM (old)* 16040749 AC Delco (old)* 213-101 GM (new)** 12223861 AC Delco (new)** 213-1562 MSD** 2313 MSD (compact)** 23131 Borg Warner** EC1678 NAPA CRB219481 Electromotive Engine Controls 71130 Holley 538-23 Tach Adapter: You won't know untill you hook the MSD up. Sometines you do sometimes you don't so just hook it up directly and see if it works If not get the adapter. Porsche CDI's over the years got mixed between years a lot so you don't know till you try. Programming If you want to run the 6AL-2 as strictly a replacement for the stock CDI you leave your distributor as is and simply program "0's" in as the timing and boost retard maps. Then you are running exactly the way you are now. If you want to run custom timing and / or boost retard maps you strip out the weights and springs in the distributor, turn the advance mechanism to full advance and pin it in place. Then you program maps for ignition timing and boost retard, this completely replaces any original mechanical mechanism You are not programming the vacumme advance you are actually programming the ignition timing curve. You will be removing the vacuum pot because it won't work with the distributor locked down so just set your static timing around 12* - 15* You can go to the MSD web site and hit the support button and download the installation manual as well as the programming manual. Wiring: I contacted Permatune and bought a male CDI connector from spare parts and wired the MSD into the connector so it plugs directly into the engine harness just like the CDI did. Go download the manuals from MSD and that will really help clear things up for ya. When you put the distributer to full advance and lock it down you'll have something like 30-40 degrees of advance dialed in permantly. Instead of dialing in advance by turning the distributor ( setting timing at 4000 RPM for 29* AND THEN LETTING THE SPRINGS AND WEIGHTS DETERMINE THE TIMING CURVE) you are now starting at full advance and programming out (subtracting from lockrd down full advance) what timing you don't need. Cole
Cole - 80 930 "The Old Sled" Mods: TurboKraft Custom IC, 934 Headers, GSX 61, Zork, Port Work, SC Cams, Air Mod Fuel Dist Relocated, Water Meth Injection, BL WUR, MSD 6530, Greddy EBC, Synapse Bov, Short 2nd & 3rd with 8:37 R&P, Wevo Shifter, Coupling, and Mounts, MTX-L SSI-4, Big Brakes, Rebel Coilovers, Bilstein Sports. Last edited by cole930; 12-09-2011 at 01:55 PM.. |
Good stuff, Cole! I'll be saving your "recipe for sucess" for future reference.
BTW, my '87 did not need a tach adapter. Fred, who knows about your '79?
I didn't mean to dodge the tach adapter question but when I bought my original
6AL I couldn't get a straight answer either. Seems like if you search the forum some guy's have had to install them and some have not and it was that way on early na cars, late cars, and turbos. Called MSD and they said a 5vdc sq wave input should work fine ????? who knows. Cole
Cole, that permatune connector tidbit you hid up there... IS AWESOME ADVICE!!! Allows you to not hack up the harness and go back to stock if ever desired. You are full of these little tidbits... LOL
JB - BreitWerks www.breitwerks.com 321-806-8664 Engine Rebuild & Restorations |
dual plug
Hey guys; this thread comes at a good time. I'm doing my install over Christmas. I will be using the BTM boost retard. Can someone direct me to a thread on wiring the 2 -6AL boxes to the cars harness. Now I am running a single MSD 6AL. Is it as simple as doubling up the wires to the harness. I hope everyone is bored over the holidays, as I know I will have lots of questions. cheers Philip
87 930 GHL/Rarlyl8/Garretson/GT3582R/1 Bar/Wevo shift, mounts/Meth inj/LM-2/Custom Fuchs/Carrera intake manifold/Xtreme Carrera heads P&P/3.4/DR 993SS cams/ Mahl/Pauter/JE/Niresist/ARP/twin COP/8.25:1/KEP stage 2/twin tials/close 2,3,4th. MS3Pro Evo ![]() ![]() |
Phil:
You can download install instructions off the MSD website. In fact, the BTM instructions even had pictures for the dumb old guy. I like pictures, a picture is worth a thousand words, now if I could just see and cure the chemo brain fade i'd get something done. JB: Even an old blind hog finds an acorn now and then. Cole
Cole - 80 930 "The Old Sled" Mods: TurboKraft Custom IC, 934 Headers, GSX 61, Zork, Port Work, SC Cams, Air Mod Fuel Dist Relocated, Water Meth Injection, BL WUR, MSD 6530, Greddy EBC, Synapse Bov, Short 2nd & 3rd with 8:37 R&P, Wevo Shifter, Coupling, and Mounts, MTX-L SSI-4, Big Brakes, Rebel Coilovers, Bilstein Sports. Last edited by cole930; 12-09-2011 at 06:26 AM.. |
Just to bump a good thread with info.
Fred
