Certifiable
Quicksilver77's Avatar
Send a message via Yahoo to Quicksilver77
Stripped holes in the case
Hi all!
In you efforts to do some while I am in there projects I have come across a stripped hole in the case used for installing the intermediate shaft cover. Would it be more wise to drill the hole a bit wider and re-tap the alloy or would a heli-coil be the better bet? As you can see by the image there is not a lot of material around the hole to begin with.
Sean D. 1987 930
India Red/Beige/Black; Mahle 3.4L; Kokeln IC; K27 7200; GHL Headers; Borla Stainless Muffler; SC cams; Sachs Aluminum Clutch; Aluminum flywheel; Bilstein Sport Shocks; Adjustable Rear Sway Bar; Weltmeister Shock Tower Brace; Lowered and Corner Balanced; MOMO RSGT Seats...
Old 10-11-2012, 03:07 PM
I've gone native
Tt surgeon's Avatar
Try running a tap down the hole
Old 10-11-2012, 06:01 PM
Certifiable
Unfortunately there is no material to tap.
Old 10-11-2012, 07:56 PM
I've gone native
Tt surgeon's Avatar
Maybe tap it to the next larger size, just run the next size tap in and cut some new threads, I would prefer that to helicoils which you can still do if tapping fails.
Old 10-11-2012, 08:17 PM
Certifiable
Fair suggestion!
Old 10-11-2012, 08:21 PM
I've gone native
Tt surgeon's Avatar
Been there....
Old 10-12-2012, 04:47 AM
Banned
A helicoil would be the much better option for me (they are easy to use, work well, and you retain the original bolt size) . . .
Old 10-12-2012, 05:55 AM
Timeserts all the way, don't waste your time with a helicoil. Been there done that, have the T-Shirt, CD and post card.
Yasin
Old 10-12-2012, 06:56 AM
Chain fence eating turbo
Helicoil is just fine when done right. That is a low torque boss, non-critical.
Old 10-12-2012, 07:25 AM
Certifiable
Conclusion
Thanks for all your input. I opted to up the bolt size and bore and tap to match. In the spirit of not having to revisit the stripped scenario I opted for a fastener that will be tough to apply enough torque to cause stripping again. Let me know your thoughts.
Sean D. 1987 930
Old 10-12-2012, 09:58 PM
Metal Guru
911nut's Avatar
I don't mean to offend you but that looks like a bodged repair job.
Our cars have value and as such, they should always be repaired to the highest standard, IMO.
Time Certs would have essentially restored the threads and allowed you to use factory fasteners.
Paul B.
'91 964 3.3 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb
Old 10-13-2012, 07:52 AM
If you're into a real low torque on those it would be better to use allen head bolts and drill a hole through the head sideways and then safety wire them so they can't come loose and fall out.
Old 10-13-2012, 10:53 AM
Hirevtuner's Avatar
wtf, use a time sert, don't take a chance.
1981 411 rwhp, Ruf intercooler, 964 cams, Turbo Kraft injector blocks, Extrude honed intake, 7006 Turbo, Tial wastegate, RarlyL8 exhaust, MSD6al
Old 10-13-2012, 03:40 PM
Certifiable
911nut and hirevtuner point taken. Thanks for the feedback!
Old 10-13-2012, 05:08 PM
