Bland
unclebilly's Avatar
Oil leak... But from where?
My 86 Euro 930 developed a bad oil leak on the way home today. I noticed smoke in the rear view, pulled over to find a leak that appears to be under the intercooler, on the drivers side. I don't think this is a valve cover or the oil pressure switch - it is definitely up top and on the driver's side. Any ideas?
Old 05-07-2013, 10:09 PM
Certified User
billjam's Avatar
The oil feed to turbo runs through there. Maybe the hose has given up, or the steel pipe may be touching something that rubbed a hole in it.
Bill
1988 Carrera - 3.6 engine with ITBs, COPs, MS3X
2024 Macan S
Day job ... www.jesfab.com.au
Memories: '68 912, '72 911T, '80 911SC, '84 911, '85 930, '86 930, '87 911, '21 Macan S
Old 05-08-2013, 05:48 AM
Bland
unclebilly's Avatar
Thanks for the photo Bill... here's hoping.
I am going to have to yank the intercooler to see what's going on. I couldnt find anything obvious with a mirror and flashlight last night.
Old 05-08-2013, 06:53 AM
I just had a bearing failure, because at the oil pump (where the turbo oil circuit attached) I was leaking a little oil. Sensible machines, careful with any oil leaks on the turbo piping!
Old 05-08-2013, 11:11 AM
Bland
unclebilly's Avatar
It looks like the oil line for the turbo is the culprit right where the hose crimps on above the valve cover...
Old 05-08-2013, 07:52 PM
