Mr. C
RUF BTR 4 Sale
This is sweeet !!!!!
" Mr.C " Six = Sex Last edited by SAY - 642; 12-14-2012 at 05:51 PM.. |
I would love to own that RUF.
1998 993 C2S Guards Red/Black 1990 964 C2 RWB project car 2016 GT3RS White Daily driver 2018 Lamborghini Performante Gegio Telesto |
Love the look of the flushed rain gutters
Is this a real RUF VIN car? I did not see the VIN in any of the pics. Thanks
1965 911 Vin 1249 Slate Grey 1969 911 Golden Green 2.0 Twin Plug 1971 911 S Gold Metallic. Peter Gregg 1974 911 RS Euro Metallic Blue Gold lettering 1991 Brumos 3.6 Turbo Pikes Peak Zwart Motor |
I think it's a conversion, albeit an extensive one, overall a pretty awesome RUF. Honestly, I can't really tell you too much because I fell asleep half way thru the video, man that Dude likes to talk !
Doug Houston, Texas 997 TT 550RUF '86 930 |
Look closer at the motor. It seems to be quite an oddity.
Looks like it was a RUF CIS turbo conversion that was converted to EFI. It still has the CIS pancake manifold and even the air filter housing which is interesting. It clearly has a quality set of EFI injectors fitted and the owner says it has a Motronic ECU. Never seen anything like this in any RUF info. Also says it has a G50 transmission not a RUF 5 spd in a 1979. Very curious. ![]() ![]() Some more info and pictures. 1979/91 RUF BTR III Motronic |
Damn...I fell asleep too...
^^^ +1
Cool car for sure - but curious about the intercooler. Is that RUF any better than a standard 964 Turbo intercooler? Seems to be thicker but less frontal area. ? And if no AC why not a full bay intercooler??
Brandon '91 911 Turbo '87 325i Convertible '16 Audi Allroad Denver, CO |
that is not a 964 interior. look at the sifter.
Ernest Johansmeier ernestj911@gmail.com |
also the wheels would not work either. this is not a 1992. no doubt.
7.0:1 > 11.3:1 > 7.0:1
Perhaps I can provide some insight regarding this car. I was a prospective buyer back in 2007/2008.
It is a 1979 911sc chassis which was worked over by RUF in 1992 IIRC. It's been built to replicate the appearance of a 965 from the outside, yet all components including interior, suspension, brakes, engine, gearbox, and chassis have been converted to resemble a well built up 1989 platform 930 with an engine rated at 405 hp. The invoice from RUF was long and comprehensive. I had a fellow with me who translated it, page after page, after page. 1979sc donor chassis rear torsion tube converted to 89 930 G50/50 box and hydraulic pedal assembly 930 trailing arms with late model spring plates Ruf four piston calipers front and rear Large two peice rotors and custom hats on all corners. Estimate 13" dia x1.25" Large sway bars both front and rear. Appear stock in layout but bar diameter is much larger than stock Large front center mounted oil cooler Larger than stock torsion bars front and rear Engine is 3.4 liter displacement with Bosch EFI, RUF invoice rates it at 405hp 930 style intake manifold with two EFI injectors per cylinder on custom injector blocks. RUF fuel rails. RUF intercooler (similar location to 930, not CTR version) RUF twin outlet exhaust 930 size flares 1991+ bumper skins, rockers, mirrors, and door handles 964 tail lights Drip rails removed Ruf five spoke wheels H4s or 5s New interior upon conversion Matter 6 pt. cage with leather padding to match interior All ruf instruments with 350km speedo (220 mph), and ruf boost gauge I recall the owner said he had the factory seats which were too small for him. Back at the time I posted a thread on rennlist about the car but chose to not go through with purchasing it. It was sort of a duplicate of my 930 I had at the time, though a little more aggressive. edit: Regarding the comment about the CIS air filter housing, this car has an assembly mounted under the filter housing which necks down to a flex tube connecting to the S pipe. It was strange to look under the filter housing and not see a CIS metering unit. Last edited by Jim2; 12-10-2012 at 11:14 PM.. |
Mr. C
Sold for 46 K
" Mr.C " Six = Sex |
Based on the addition of the translation, this looks like a very interesting piece of RUF history after all.
Looks like a ground up build off a SC donor chassis. Unique RUF motor build with Motronic slipped in place of the expected 930 CIS. Motor looks like it could pass visual for a 79 930. Someone should document that motor build. Last edited by 911st; 12-23-2012 at 12:12 PM.. |
Someone should put the wipers back to origonal configuration, they look like crap like that.
The reason left side drive cars have them on the left at rest and right side drive cars have them at rest on the right side is so when you turn them on in the rain the first swipe clears the windsheild for the driver and the driver could scoot off immediatly, especially at the traditional start of LeMans if it's raining. The Porsche engineers had it right. The reason for the ignition switch on the left side of the steering wheel was so the driver could start the car with one hand and put it in gear with the other hand... also saving precious time at the traditional start of LeMans back when the drivers ran across the starting grid to their cars, hopped in, harnessed up, started it, and took off as fast as they could at the start of the race. |
Imho, I think the car would have been worth more if it was stock in appearance. Even better yet, narrow body with BTR spoiler like one the red one.
I found it strange that this car was built in 1992 when the 965 had already been in production. For the money spent a used 1991 965 could have been purchased then have it's motor swapped for the BTR unit. There wouldn't have been any need to do a complete teardown and re-fender the car, secure a turbo 5 spd box, change out the T-bar tube etc etc only to make this car look like a 965. Makes me wonder what the customers motivation was.
Bland
Does anyone know who bought it! Is it going to stay local?
06 Cayenne Turbo S and 11 Cayenne S 77 911S Wide Body GT2 WCMA race car 86 930 Slantnose - featured in Mar-Apr 2016 Classic Porsche Sold: 76 930, 90 C4 Targa, 87 944, 06 Cayenne Turbo, 73 911 ChumpCar endurance racer - featured in May-June & July-Aug 2016 Classic Porsche |
I kind of believe that if this is what it seems, it was not marketed very well, is pretty rare, and could be worth a pile.
Not saying it is the most desirable RUF style but is it one of the more unique in several ways. It is a one off, customer spec, turbo bodied, built on an older VIN, and in my mind -- with a very rare motor build. Looks like this is the EFI Pressure Sensing, Twin Injector, injection system originally used on the record breaking Yellow Bird CTR. But adapted to the single turbo 930 / pancake manifold and plumbing. If so, this is probably more rare than the original Yellow Birds abet not as desirable. Not a big fan of the C2 bumpers or the turbo flairs for that matter, but if it is on the RUF build sheet I do not think I would change it. Again, it looks like it is based on the following long block and injection system but adapted to the 930 intake:
If the it looked like this. He could have named his price.... Narrow body. Front Spoiler, BTR engine. REAL BTR.
