drl911's Avatar
Carrera Supercharger installed
Install is complete... here are the details and pics...
'86 Carrera, already had headers, M&K 2in/2out, ARP head bolts, modified cam and chip making 229 HP at the wheels a few years ago on a Dynojet. It is also gutted and fitted with lots of fiberglass for mostly DE duty at 2200 lbs.
Additions...
Vortech V1 A trim supercharger
MSD 6 BTM
AEM wideband A/F ratio gauge
BOV
Boost gauge
I made the supercharger bracket myself by layering 1/4" aluminum plates. It is mounted to the engine carrier and is very stable. The stock AFM is on the suck side. The BOV is plumbed from the pressure side of the supercharger back to the input side after the AFM. I started with a vortech 8:1 FMU, but everything went dead rich 10.0 when the boost kicked in. I pulled the FMU and made a few test drives with just the factory FPR and the stock 24lb/hr fuel injectors and to my surprise it works just fine. The AFM seems to communicate to the ECU just fine up to about 3500 rpm (according to the A/F ratio gauge, 14.0~14.5). At 3500 rpm and above it seems the barn door is full open due to the supercharger, but at the same time the factory FPR reacts to the boost and the A/F ratio gauge indicates about 11.5 ~ 12.0 up to 6000 rpm. I haven't notice any difference turning the MSD timing retard knob, but I hope to get dyno time in the next few weeks to get actual data, but so far things are encouraging. I see the boost gauge getting to 7psi before 6000 rpm so I may change the 3" pulley to 3.25" or look into the boost limiter sold by 928motorsports. I was able to get a 0-60 mph pull of 4.78secs per my AIM solo GPS track timer, a full second faster than before the supercharger. Questions, comments??? Thanks, Dan
Can I ask you a question? Sure, what is it? An interrogative statement that tests ones knowledge, but that's not important now....
'86 Carrera . . . '87 951 destroyed by drunk driver ... '01 Boxster S. . . '04 Cayenne S . . .
Old 11-24-2012, 04:23 PM
Non User
infraredcalvin's Avatar
That intake in the cabin must sound sweet, my old supercharged lighting used to suck air like mad when I jumped on it. Any hp and tq numbers now after install?
Infraredcalvin - AKA Pat
'76 Turbo Carrera #311 - Factory LSD, Sport Seats
‘71 914-6 GT 3.4L twin plug track car
'75 914 GT clone project
'71 914 track car, fresh 2165 FAT motor (for sale soon)
Old 11-24-2012, 04:31 PM
jsveb's Avatar
Comments: super sweet
May I ask: How much in parts?
Jesper
Carrera 3.0 1975
930 1978 OEM Matte Schwartz, ANDIAL IC, BL WUR, SC cams. LMA-3 w. XD-16 and CP transducer
www.stauningwhisky.dk
Old 11-24-2012, 04:59 PM
drl911's Avatar
Trying to schedule dyno time soon, no numbers yet.
Air filter "breathing" sounds nice, supercharger "chirping" is a little annoying, but probably won't notice it much with helmet on!
Total cost for parts (drum roll..........) $1650
Old 11-24-2012, 05:31 PM
Prrrrreeeeetttty cool!
And no lag - right?
Old 11-24-2012, 05:48 PM
spence88mph's Avatar
Nice clean install, looks great. 4.78 is quick and I imagine that is without killing the 915. If the charge is cool enough you can go to 10psi. Good work and pricing, maybe you could share the mount drawings with those wanting to mount a supercharger, has been a few lately.
'89 911 M491+Turbo
'89 944 Turbo
'88 928S4
'18 C63S Coupe
Old 11-24-2012, 05:51 PM
jsveb's Avatar
Sounds like cheap HP. you also make it seem like you just did this in an afternoon - cool
My guess is, you are about 330 CHP
Let us know...
Jesper
Carrera 3.0 1975
Old 11-24-2012, 06:33 PM
drl911's Avatar
If you have all the main components, fabrication skills and a good local hardware store, it's a 3 day job.
Old 11-24-2012, 06:41 PM
Chain fence eating turbo
Good to see some SC installs after all the boring turbo installs. "A" trim, the one that started it all! It's great to just regulate fueling with either a FMU or how I think you did of using the boost signal only to enrichen the FPR. BTW Protomotive uses ~4:1 ratio for rising rate if that helps, but it sounds you are just fine.
I bet the torque down low is pretty good.
Old 11-25-2012, 03:40 AM
Grappler
Rodsrsr's Avatar
Very nice setup!
Grappler
Know Gi / No Gi
1976 RSR Backdate (Turbo 3.2)
Old 11-25-2012, 09:29 AM
Dr J's Avatar
Congratulations! Very important to check the AFRs as you have done. Do you have a tail? Did you have to cut the deck lid?
1979 SC, Slant nose wide-body cab conversion. AEM Infinity EFI, COP, supercharged!
Old 11-25-2012, 11:11 AM
drl911's Avatar
Deck lid was already cut for weight savings
before pic....
Old 11-25-2012, 11:18 AM
mfyoung1086's Avatar
Can I ask how did you modify the crank pulley for the supercharger belt, and maybe some more belt details in general?
____________________
1985 Carrera: Big Reds = Ass Saver
Old 11-25-2012, 10:37 PM
Certified User
billjam's Avatar
Nicely done and well thought out. This is something I have always wanted to do to a 3.2 or 3.6.
I, and others, would love to see a few more pics of your setup, so don't be shy about posting some more details.
Bill
1988 Carrera - 3.6 engine with ITBs, COPs, MS3X
2024 Macan S
Day job ... www.jesfab.com.au
Memories: '68 912, '72 911T, '80 911SC, '84 911, '85 930, '86 930, '87 911, '21 Macan S
Old 11-26-2012, 04:14 AM
I'd like to add that a braided line for the oil squirter would look a lot better.
Old 11-26-2012, 04:44 AM
drl911's Avatar
No change to the crank pulley was required because I am using the same type V belt that the AC compressor used to use. So far no belt slipping that I can detect.
Old 11-26-2012, 05:05 AM
drl911's Avatar
I will post some more close up pics this evening.
Old 11-26-2012, 05:06 AM
Very nice install, and inexpensive! I would love to do this to my 84 Cab at some point. Nice work.
When the common bond is a Porsche, the people who own them are even more interesting than their cars.
Old 11-26-2012, 05:20 AM
Champagne on Beer Budget
HelmetHead's Avatar
Very nicely done! Just a thought, you might consider replacing the rubber intake 90 in the future with one that can hold up to boost...my 3.2 piece blew out after a few weeks in a turbo application
Einar
www.einarsgarage.com
Instagram @einars_garage
https://www.facebook.com/pages/Einars-Garage/375533809160797
Old 11-26-2012, 05:40 AM
Grappler
Rodsrsr's Avatar
That's true. Mine blew out too so I moved to a silicone piece.
Grappler
Know Gi / No Gi
Old 11-26-2012, 07:02 AM
